- To:
- Subject: Questions about Nef_3 polyhedron
- Date: Tue, 20 Feb 2007 09:44:55 +0100
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=beta; h=received:message-id:date:from:to:subject:mime-version:content-type; b=qNz+44+65+MfkVNB3mS0fwNM53adrUW6c9/CBmtNPPM94jnULTb9hcHKSbqtiDhx/7g9fiYm2YjasPEZYATKfDpqOoOCbqKaGF3aLQ2F+/vA1UoAzjvZJIu1rse3JYb0yTm0tn/+wTViGatiMRzKplcg1kp2BINkgPAjRXNyZsk=
Hi. I have questions about Nef_3 polyhedron.
Question 1 :
If I made a Nef_3 polyhedron with a plane (0,0,1,-20), a simple z=20,
what region does the polyhedron represent ?
Is it the upper region or the lower region of the plane ?
Following to the example about converting Polyhedron_3 to Nef_polyhedron_3,
I created a simple tetrahedron and converted it to Nef_polyhedron_3.
In this case, the region Nef_polyhedron_3 represents is inside of the
tethedron ?
Question 2 :
Let's assume that I create a triangular mesh model (for examle, a cube)
with Polyhedron_3 by using incremental builder and convert it to a
Nef_polyhedron_3.
If all the facets outward normal vector, what region the converted
Nef_polyhedron_3
represents, inside the mesh or outside ?
Question 1 :
tethedron ?
Question 2 :
Nef_polyhedron_3.
Nef_polyhedron_3
- Questions about Nef_3 polyhedron, Wonwoo Lee, 02/20/2007
- <Possible follow-up(s)>
- Questions about Nef_3 polyhedron, wwlee06, 02/20/2007
