cgal-discuss - Re: [cgal-discuss] How to store an existing triangulation in CGAL
  • To:
  • Subject: Re: [cgal-discuss] How to store an existing triangulation in CGAL
  • Date: Thu, 22 Feb 2007 16:33:11 -0500
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=beta; h=received:message-id:date:from:to:subject:in-reply-to:mime-version:content-type:references; b=W4aXgz+mUWRfI6dQKJYSVOTyhXDg+glsV6ZQA+UZqucwSRlVc9rCLkbP2nNUBaE/krafTsa3R6Eut5rpHSs4CWRxGECV/YnldKJVCcueMLoz6LGofC1ipix+6DeNlewUpfwn2YIUtNvtTSRr5CWmJ6iG3yADn4u636aLiu4PJis=
If your mesh is not convex then I would not recommend that approach.
On 2/22/07, Olumide <> wrote:
Damian Sheehy wrote:
> Well, if your mesh is contained in a file on disk, you may want to
> consider writing a script that converts that mesh into the
> Triangulation_2 format. The Triangulation_2 file could then be read into
> CGAL using the Triangulation_2 >> operator.
Thanks.
Can you (or anyone please) send me an example of such a triangulation file?
One last question, or note of concern. Will my triangulated mesh be
considered valid? - even if its bounded faces do not form a convex hull
of the set of vertices it consists of.
- Olumide
