cgal-discuss - Re: [cgal-discuss] Triangulation not empty after creation?
  • To:
  • Subject: Re: [cgal-discuss] Triangulation not empty after creation?
  • Date: Mon, 26 Feb 2007 18:52:26 +0100
thanks for your help
Reply-To:
To:
Date: Sat, 24 Feb 2007 21:35:26 +0100
The vertex is the infinite vertex
wrote:
Here is my (simple) code (only the necessary parts of course):
struct K : CGAL::Exact_predicates_inexact_constructions_kernel {};
typedef CGAL::Triangulation_euclidean_traits_xy_3<K> Gt;
typedef CGAL::Delaunay_triangulation_2<Gt> Delaunay;
Delaunay dt;
void
siaDelaunay::SetVerticies(std::vector<std::vector<float> > points)
this->PrintSelf();
for (std::vector<std::vector<float> >::const_iterator it = points.begin() ;
it != points.end() ;
it++) {
cgalPoint P((*it)[0], (*it)[1], (*it)[2]);
this->dt.insert(P);
this->PrintSelf();
this->PrintContent();
PrintSelf() prints current verticies/edges/faces #
PrintContent() prints verticies geometry
and here is the (surprising) output when a single vertex is added to the triangulation:
siaDelaunay: 1 verticies, 0 edges, 0 faces
siaDelaunay: 2 verticies, 0 edges, 0 faces
siaDelaunay: -1.992622 20358369408.661587 -1.992669
siaDelaunay: 42.200001 37.599998 0.000000
which means that the triangulation already contains an invalid vertex just after being created!!
Any explaination?
_________________________________________________________________
Gagnez des écrans plats avec Live.com http://www.image-addict.fr/
