- To:
- Subject: How to mesh an hyperboloid implicit surface?
- Date: Thu, 08 Mar 2007 19:18:16 +0100
Hello Everybody,
I would like to mesh an hyperboloid implicit surface (equation is: -x2 + y2 +z2 -R ). In order to perform that, I used the little script in the CGAL manual ( In the 3D surface mesher section). It works well for the sphere equation but crashes for the hyperboloid equation.
I try to change the meshing criteria:
When I used: criteria (30. , 0.9 , 0.9 ) I have the following error message:
CGAL error: assertion violation!
Expr: false
File: /home/Chavent_Matthieu/CGAL-3.2.1/include/CGAL/Delaunay_triangulation_3.h
Line: 1054
Aborted (core dumped)
When I used: criteria(30. , 1. , 1. ), it works...
But I would like to decrease the radius bound and the distance bound to have a better precision..
Someone have an idea?
Thank you in advance!!!
Matthieu Chavent
LORIA
PhD student
- How to mesh an hyperboloid implicit surface?, Matthieu Chavent, 03/08/2007
- Re: [cgal-discuss] How to mesh an hyperboloid implicit surface?, Laurent Rineau, 03/08/2007
