cgal-discuss - Re: [cgal-discuss] Cannot use Cartesian<double> for the convex_hull_3 function!
  • To:
  • Subject: Re: [cgal-discuss] Cannot use Cartesian<double> for the convex_hull_3 function!
  • Date: Sat, 10 Mar 2007 08:13:04 -0500
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=beta; h=received:message-id:date:from:to:subject:in-reply-to:mime-version:content-type:references; b=C9mr+T4hmkP+9hAsxavAQljxt6zlmrx/MPGjBvDA+G4Uu5rmZKHBNsH0FPGpwI/BWGDQPTETtzhAqtwlT4aQiNaO1+gCa765hjyrT5Jr/37eZaVDui3riNMty/S8jvh7D8kA323pFrfoRjioYEOo5/2WtFSWnmP27Vyol27qBzA=
Hi,
As far as I know, convex hull computation uses exact predicates and I guess it is slow because of this (but not awfully slow as your email seems to suggest). It does work sometimes (but not always) just with Cartesian<double> but you have to superimpose that with the exact predicates. Moreover, it works fine with double and not restricted just to Homogeneous types. Hope this clarifies your concerns.
Raman.
Purdue University.
On 3/10/07, BBB HHH <> wrote:
Hello,
I am using the tutorial of pierre alliez, but when using enriched_polyhedron with the the Cartesian<double>, it takes a lot of time to compute just the convex hull of 48 vertices, i want to know if the function convex_hull_3 is restricted to use with only Homogeneous types or not.
Découvrez une nouvelle façon d'obtenir des réponses à toutes vos questions ! Profitez des connaissances, des opinions et des expériences des internautes sur Yahoo! Questions/Réponses.
