- To:
- Subject: Problem with convex_hull_3 and enriched_polyhedron
- Date: Tue, 13 Mar 2007 08:27:48 +0000 (GMT)
- Domainkey-signature: a=rsa-sha1; q=dns; c=nofws; s=s1024; d=yahoo.fr; h=Message-ID:X-YMail-OSG:Received:X-Mailer:Date:From:Subject:To:MIME-Version:Content-Type; b=fR1/C9N64pJJ18B84oWeSjVQCnEs4FTOS5npgwT7xlZlZSN3O7vHTrhnyrBfAC2IhjIK6jeybStcn/e7K7yIgc5pP2KCOR4vwE6JxMHuY0Ywx5wt+VlhHRuzW71pcthp8AMs77Xhnz+d9TU2tqJcAgNE43Dp3RVS1ni6xVmdbwQ= ;
Hi,
I am using convex_hull_3, but it makes a very long time and does not stop computing (with the tutorial of Le-Jeng Shiue, Pierre Alliez, Radu Ursu and Lutz Kettner, http://www.cgal.org/Tutorials/Polyhedron/index.html) , even for 48 vertices, i tried to do with MP_Float, Gmpz, Gmpq with Homogeneous but the problem still exists, can you tell me if Gmpz can store float numbers? and how to convert between the different number_types. I want to know how to convert from a Polyhedron_3 with for example Cartesian<double> or simple_cartesian<double> to Polyhedron_3 with Homogeneous<MP_Float> or Homogeneous<Gmpz>. Finally, i want to know how i can convert from enriched_polyhedron<double> to CGAL::Polyhedron_3<CGAL::MP_Float> in the tutorial.
Thanks in advance
Hichem
Thanks in advance
Hichem
Découvrez une nouvelle façon d'obtenir des réponses à toutes vos questions ! Profitez des connaissances, des opinions et des expériences des internautes sur Yahoo! Questions/Réponses.
- Problem with convex_hull_3 and enriched_polyhedron, BBB HHH, 03/13/2007
