- To:
- Subject: Re: [cgal-discuss] How to get the index of the K-Nearest Neighbor points
- Date: Tue, 13 Mar 2007 11:11:05 +0100
Sophea,
With the existing code this cannot be done effeciently, since the K-Nearest neighbor object stores point copies. You have to adapt the Orthogonal_k_neighbor_search class in such a way that is stores point pointers (or point references). Not vey difficult to do.... After that the index can be computed by simple pointer arithmetic.
If you are interested, I can send my code which contains those changes and some additional <ende?lp=ende&p=/gQPUD&search=additional> optimisation <ende?lp=ende&p=/gQPUD&search=optimisation>s.
Cheers,
Johannes
Chansophea Chuon wrote:
Dear All:
Suppose that we pass a vector of points(std::vector<Point_3 <http://www.cgal.org/Manual/3.2/doc_html/cgal_manual/Kernel_d_ref/Class_Point_d.html#Cross_link_anchor_361>> points) to the (Tree tree(points.begin(), points.end()))
Then we find the K-Nearest neighbors
Neighbor_search search(tree, query, N);
// This should sort all N points by increasing distance from origin
for(Neighbor_search::iterator it = search.begin(); it != search.end(); ++it){
std::cout << it->first << " "<< std::sqrt <http://www.cgal.org/Manual/3.2/doc_html/cgal_manual/NumberTypeSupport_ref/Function_sqrt.html#Cross_link_anchor_1176>(it->second) << std::endl;
We get the K-Nearest neighbors points and their distances. How to get the index of the K
-Nearest neighbors in the vector effeciently? Does the Neighbor_search::iterator provide the indexes?
Best regards,
Sophea
Don't get soaked. Take a quick peek at the forecast <http://tools.search.yahoo.com/shortcuts/?fr=oni_on_mail&#news>
with theYahoo! Search weather shortcut. <http://tools.search.yahoo.com/shortcuts/?fr=oni_on_mail&#news>
- How to get the index of the K-Nearest Neighbor points, Chansophea Chuon, 03/12/2007
- Re: [cgal-discuss] How to get the index of the K-Nearest Neighbor points, Johannes Otepka, 03/13/2007
