cgal-discuss - Re: [cgal-discuss] installation problem CGAL 3.2.1 +QT on linux
  • To:
  • Subject: Re: [cgal-discuss] installation problem CGAL 3.2.1 +QT on linux
  • Date: Fri, 16 Mar 2007 18:37:14 +0100
Hi Laurent, Joachim and Everyone,
Thank you so much for your help. It turned out, the generated make
file for CGAL 3.2.1 for some reason was missing the
following lines:
/usr/local/qt/bin/moc
/usr/local/CGAL-3.2.1/include/CGAL/Kinetic/IO/internal/Qt_widget_2_core.h
-o Kinetic_Qt_widget_2_core.moc
/usr/local/CGAL-3.2.1/include/CGAL/Kinetic/IO/internal/Qt_core.h -o
Kinetic_Qt_core.moc
/usr/local/CGAL-3.2.1/include/CGAL/Kinetic/IO/internal/Qt_timer.h -o
Kinetic_Qt_timer.moc
/usr/local/CGAL-3.2.1/include/CGAL/Kinetic/IO/internal/Qt_window_2.h
-o Kinetic_Qt_window_2.moc
I run those commands within directory CGAL-3.2.1/src/CGALQt.
And then went thru re-compilation.
Thanks!
Alena
  • Re: [cgal-discuss] installation problem CGAL 3.2.1 +QT on linux, alenas, 03/16/2007
