- To:
- Subject: A question about the 3D triangle projection.
- Date: Fri, 30 Mar 2007 22:44:07 +0200
Hi, may I ask a question?
If I project a 3D triangle into a 2D plane by perspective projection,
then all the interior points in the 3D triangle will project into the
interior of the 2D projected triangle.
I think it is true, but could you tell me whether there is a lemma to
describe it?
Thank you for your help.
Songxiang Gu
- A question about the 3D triangle projection., songxiang . gu, 03/30/2007
