cgal-discuss - Re: [cgal-discuss] Re: Intersection of 3D triangulations
  • To:
  • Subject: Re: [cgal-discuss] Re: Intersection of 3D triangulations
  • Date: Tue, 10 Apr 2007 08:50:53 +0200
Then it is easy to query the alpha shape data structure
for tetrahedra that are in the alpha complex for one of the alpha
valu and not for the other :
iterate on the Delaunay or regular tetrahedra
and for each of them call the classify() function
with the alpha_values of interest.
Philipp Richter CGAL wrote:
Dear Mariette,
I think I confused a word. I do not want to intersect them (this really would be a bad idea), but to find the difference of them. If A and B are polyhedra (triangulations in this case), then I want the difference polyhedra C = A - B.
Sorry for confusion.
Philipp
Mariette Yvinec writes:
Hi CGAL users!
I am currently working on alpha shape triangulations of 3D point sets and would like to find intersections of those alpha shapes (same point set, different alpha values).
What would be a way to do this? It seems like one can find 3D intersections of NEF Polyhedra. So converting my alpha shapes to Nef Polyhedra, then find the intersection and then triangulate again (I want to have a triangulation in the end) sounds like it works but also sounds wasteful.
Is there a way to intersect triangulations easily? I did not find information on this in the manual or using google.
Thank you for your help!
Philipp Richter
Alpha_shapes for the same point sets and different alpha value
are subcomplexes of the same 3D Delaunay triangulations.
The different alpha_shapes are thus nested,
and their boundary facets will be either shared,
or sharing edges or disjoint.
So it is of course possible, but may be a somewhat bad idea to intersect them.
If really you want to intersect them, Cgal as a package called
"Intersecting sequences of iso-oriented box" which is dedicated to this kind of application.
Look at the examples in the corresponding chapter of the user manual .
