- To:
- Subject: convex hull 3d
- Date: Wed, 16 May 2007 04:21:56 +0400
Hello everybody,
I work on comparing robustness of convex hull 3D algorithms, so first thanks
all the CGAL developers: I have one more implementation to compare. But I
have some questions:
1) Why does implementation of quickhull algorithm (CGAL::convex_hull_3) has
such strange
performance results? For testing purpose code snippet from
CGAL-3.2.1/examples/Convex_hull_3/quickhull_3_ex.C was taken. Only point
generation was changed from distribution in sphere to distribution on sphere.
Here results:
- processing of 10000 points on sphere takes 31594 ms;
- 20000 points takes 94375 ms
- 30000 points takes 170953 ms
- 40000 points takes 286484 ms
- 50000 points takes 409719 ms.
It seems, that algorithm doesn't related to algorithms with O(n*log(n))
complexity on given distribution, because constant C in C*n*log(n) expression
has such relative rates: 1.389, 1.160, 1.223, 1.121 (relative rate implies
the following ratio: C_{i+1} / C_i).
2) Why does facet orientations differ in quckhull (ccw in to see to facet
from outside) and randomized incremental algorithms (cw)?
Thanks in advance.
Sergey.
- convex hull 3d, Sergey Simonchik, 05/16/2007
