- To:
- Subject: Follow-up: [cgal-discuss] Segment missing in planar map?
- Date: Tue, 22 May 2007 11:43:05 +0200 (CEST)
- Organization: Institut fuer Werkstoffe TU Braunschweig
Dear experts,
I still have not solved the problem described below. I tried to insert
the segments one by one as follows:
Pmwx pm;
for (unsigned int i=0; i< seglist.size(); i++)
pm.insert(seglist[i]);
but still one of the segments is missing from the planar map in some cases.
I would really appreciate any insight on why this can happen and what
to do about it. Is there any kind of assertion I can use to check
whether the segment was actually inserted?
Thanks,
Martin.
PS: I still use CGAL 3.1 - is there a chance that upgrading to a later
version will help?
> Dear all,
> I just encountered a puzzling behaviour in a Planar map.
> I use the following code fragment to create the planar map:
> std::vector<Segment> seglist //This is the standard template library vector
> class
> ... seglist filled with values
> Pmwx pm;
> pm.insert(seglist.begin(), seglist.end());
> std::cout << "\n\nWriting pm's halfedges" << std::endl;
> Pmwx::Halfedge_const_iterator eit;
> for (eit = pm.halfedges_begin(); eit != pm.halfedges_end(); ++eit, ++eit)
> std::cout << eit->source()->point()
> << " --- " << eit->target()->point() << std::endl;
> In most cases, this works fine, but
> I just encountered a case where one of the elements of a
> seglist is missing in the Pmwx pm (and it is neither the first nor the
> last element, so it seems not to be a problem with the
> seglist.begin() or end()).
> Here's the bunch of defintions I use:
> typedef CGAL::Quotient<CGAL::MP_Float> NT;
> typedef CGAL::Cartesian<NT> TutorialR;
> typedef CGAL::Segment_2<TutorialR> Segment;
> typedef CGAL::Arr_segment_traits_2<TutorialR> Traits;
> typedef CGAL::Pm_default_dcel<Traits> Dcel;
> typedef CGAL::Planar_map_2<Dcel,Traits> Planar_map;
> typedef CGAL::Planar_map_with_intersections_2<Planar_map> Pmwx;
> I don't know if looking at the actual values can help in understanding
> this problem, but just in case, I'll show them here:
> This is the contents of seglist:
> i: 0 0.10000008344650269/1 0.012000012211501598/1 - 0.24999982118606567/1
> i: 1 0.10000009089708328/1 5.8278321573111952e-38/1 -
> i: 2 0.10000009089708328/1 5.8278321573111952e-38/1 -
> 0.26000073552131653/1 4.9593527711929177e-38/1
> i: 3 0.26000073552131653/1 4.9593527711929177e-38/1 -
> 0.25993925333023071/1 0.00057996663963422179/1
> i: 4 0.25993925333023071/1 0.00057996663963422179/1 -
> 0.25975009799003601/1 0.0011668455554172397/1
> i: 5 0.25975009799003601/1 0.0011668455554172397/1 - 0.25943571329116821/1
> 0.0017639140132814646/1
> i: 6 0.25943571329116821/1 0.0017639140132814646/1 - 0.25900107622146606/1
> 0.0023707395885139704/1
> i: 7 0.25900107622146606/1 0.0023707395885139704/1 - 0.25845640897750854/1
> 0.0029852592851966619/1
> i: 8 0.25845640897750854/1 0.0029852592851966619/1 - 0.25781622529029846/1
> 0.0036053736694157124/1
> i: 9 0.25781622529029846/1 0.0036053736694157124/1 - 0.25709828734397888/1
> 0.0042295018211007118/1
> i: 10 0.25709828734397888/1 0.0042295018211007118/1 -
> 0.25632262229919434/1 0.004856607411056757/1
> i: 11 0.25632262229919434/1 0.004856607411056757/1 - 0.25551068782806396/1
> 0.0054860818199813366/1
> i: 12 0.25551068782806396/1 0.0054860818199813366/1 -
> 0.25468483567237854/1 0.0061176484450697899/1
> i: 13 0.25468483567237854/1 0.0061176484450697899/1 -
> 0.25386759638786316/1 0.0067513072863221169/1
> i: 14 0.25386759638786316/1 0.0067513072863221169/1 - 0.2530810534954071/1
> 0.0073873363435268402/1
> i: 15 0.2530810534954071/1 0.0073873363435268402/1 - 0.25234633684158325/1
> 0.0080263437703251839/1
> i: 16 0.25234633684158325/1 0.0080263437703251839/1 -
> 0.25168305635452271/1 0.0086693689227104187/1
> i: 17 0.25168305635452271/1 0.0086693689227104187/1 -
> 0.25110900402069092/1 0.0093179969117045403/1
> i: 18 0.25110900402069092/1 0.0093179969117045403/1 -
> 0.25064021348953247/1 0.0099743315950036049/1
> i: 19 0.25064021348953247/1 0.0099743315950036049/1 -
> 0.25029110908508301/1 0.010640442371368408/1
> i: 20 0.25029110908508301/1 0.010640442371368408/1 - 0.25007474422454834/1
> 0.011316764168441296/1
> i: 21 0.25007474422454834/1 0.011316764168441296/1 - 0.24999982118606567/1
> And this is the output from the above code fragment when given this seglist:
> 0.10000008344650269/1 0.012000012211501598/1 --- 0.24999982118606567/1
> 0.25007474422454834/1 0.011316764168441296/1 --- 0.24999982118606567/1
> 0.25029110908508301/1 0.010640442371368408/1 --- 0.25007474422454834/1
> 0.25064021348953247/1 0.0099743315950036049/1 --- 0.25029110908508301/1
> 0.25110900402069092/1 0.0093179969117045403/1 --- 0.25064021348953247/1
> 0.25168305635452271/1 0.0086693689227104187/1 --- 0.25110900402069092/1
> 0.25234633684158325/1 0.0080263437703251839/1 --- 0.25168305635452271/1
> 0.2530810534954071/1 0.0073873363435268402/1 --- 0.25234633684158325/1
> 0.25386759638786316/1 0.0067513072863221169/1 --- 0.2530810534954071/1
> 0.25468483567237854/1 0.0061176484450697899/1 --- 0.25386759638786316/1
> 0.25551068782806396/1 0.0054860818199813366/1 --- 0.25468483567237854/1
> 0.25632262229919434/1 0.004856607411056757/1 --- 0.25551068782806396/1
> 0.25709828734397888/1 0.0042295018211007118/1 --- 0.25632262229919434/1
> 0.25781622529029846/1 0.0036053736694157124/1 --- 0.25709828734397888/1
> 0.25845640897750854/1 0.0029852592851966619/1 --- 0.25781622529029846/1
> 0.25900107622146606/1 0.0023707395885139704/1 --- 0.25845640897750854/1
> 0.25943571329116821/1 0.0017639140132814646/1 --- 0.25900107622146606/1
> 0.25975009799003601/1 0.0011668455554172397/1 --- 0.25943571329116821/1
> 0.25993925333023071/1 0.00057996663963422179/1 --- 0.25975009799003601/1
> 0.10000009089708328/1 5.8278321573111952e-38/1 --- 0.26000073552131653/1
> 0.26000073552131653/1 4.9593527711929177e-38/1 --- 0.25993925333023071/1
> As you can see, the second entry (i:1) of the seglist is missing.
> If anybody can give me a hint on what the error might be, I'd be very
> grateful, for I'm completely stymied.
> Thanks a lot,
> Martin.
> Priv.-Doz. Dr. Martin Bäker
> Institut für Werkstoffe
> Technische Universität Braunschweig
> Langer Kamp 8
> 38106 Braunschweig
> Germany
> Tel.: 00-49-531-391-3073
> Fax 00-49-531-391-3058
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
Langer Kamp 8
38106 Braunschweig
Germany
- Segment missing in planar map?, Martin Baeker, 05/21/2007
- Follow-up: [cgal-discuss] Segment missing in planar map?, Martin Baeker, 05/22/2007
- Re: Follow-up: [cgal-discuss] Segment missing in planar map?, Efraim Fogel, 05/28/2007
