- To: "cgal-discuss" <>
- Subject: [cgal-discuss] Testing if point is contained in a convex hull
- Date: Thu, 24 May 2007 21:29:22 +0800
hi,
the CGAL is a new lib for me, i need a function
to construct a "buffer" of some points,or some lines,
or some polygons. I notice there is something smiliar
in chapter 16 of the manul <<2D Straight Skeleton and
Polygon Offsetting>>.
I copy the example code to my project, compile and link
is all right, however, when running there is no result.
When debug the program, I found the following code throw
a exception:
boost::shared_ptr<Ss> ss = ssb.construct_skeleton();
I feel so depressed, maybe you can tell me why, or give
me another sample. Thanks a lot!
Natty
- [cgal-discuss] Testing if point is contained in a convex hull, Natty, 05/24/2007
