cgal-discuss - Delaunay function
Delaunay function
  • To:
  • Subject: Delaunay function
  • Date: Sat, 2 Jun 2007 14:00:56 +0200
Thanks I downloaded the last version...It's working now!
By the way...I have to modelize a terrain with Delaunay. Which example of
source code is interesting for that ?
I would like to take many points from a file and give them to a delaunay
function. Moreover I'd like to recover all the triangles generated by the
Delaunay function..
Is that possible ?
Yours sincerely.
2007/6/1, Fernando Cacciola
> Hello,
> > My IDE is Microsoft Visual Studio 2005 and my parameters are in the
> > tools->options->VC++ Directories :
> > -include files : C:\boost\boost_1_34_0\ and $(CGALROOT)\include and
> > $(CGALROOT)\include\CGAL\config\msvc7
> > -library files : C:\boost\boost_1_34_0\libs and $(CGALROOT)\lib\msvc7
> It seems you had an earlier version of CGAL already installed.
> It also seems that you created a project file of your own (instead of
> using
> the .vcproj provided)
> Starting from Version 3.3, VC8.0 (Visual Studio 2005) is supported besides
> VC7.1, thus, the folder "msvc7" is now named "msvc".
> Can you correct the VC++ directories accordingly and report back if it
> works
> now?
> This issue is described in the document "INSTALL.win32.txt", at the very
> bottom.
> Please read all the release notes in that document to become aware of the
> other important differences with respect to previous versions of CGAL.
> HTH
> Fernando Cacciola
> GeometryFactory
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
  • Delaunay function, pat, 06/02/2007
