- To: <>
- Subject: Angle between vectors
- Date: Mon, 4 Jun 2007 16:12:11 +0100
Hi
all,
I need to compute
the angle between two vectors. I've got two Vector_3 objects and I was thinking
to compute their dot product and then divide this by the product of the
magnitude of the two vectors. The problem is that I can't evaluate the sqrt of
the sum of the squared components of the vectors. Is there an in-built function
that computes the magnitude of a vector.
Another possibility
would be using Direction_3, but it seems that there is no dot product defined
for this object.
Anyway, if I
transform my vectors into Direction_3 objects and then I transform the
Direction_3 objects into vector do I end up with unit vectors? In this case I
could easily evaluate the dot product of these vectors and I have solved my
problems.
Thank
You
Angelo
- Angle between vectors, Tardugno, Angelo, 06/04/2007
- Re: [cgal-discuss] Angle between vectors, Martin Baeker, 06/05/2007
