Re: [cgal-discuss] Is there any problem if I disable the auto-link for TAUCS lib?
- To:
- Subject: Re: [cgal-discuss] Is there any problem if I disable the auto-link for TAUCS lib?
- Date: Thu, 07 Jun 2007 13:44:31 +0200
- Organization: INRIA Sophia-Antipolis
Hi,
If converting a vcproj from CGAL 3.2, you should remove the LAPACK/TAUCS libs that are explicitely specified in the linker options.
The auto-link feature for TAUCS in CGAL 3.3 will automatically select the appropriate TAUCS libraries based on the current compiler and the current runtime.
* Supported compilers are: VC++ 7.1 and 8.0.
* Supported runtimes are *release* runtimes: DLL multithread (/MD), Multithread (/MT) and Single thread (/ML).
Due to a conflict with TAUCS, you cannot use *debug* runtimes. You will get a link error if you try.
Note that VC++ can debug an application with a release runtime.
See Taucs_parameterization example in CGAL-3.3\examples\Surface_mesh_parameterization\Parameterization_examples.sln.
Best regards,
Laurent Saboret
a écrit :
I am confused that why the new CGAL provides auto-link for TAUCS? Is there
need to link different taucs libs for different compilers(vc7.1 or vc8.0) and
for different configurations(debug or release, mt dll or other)?
If I disable the auto-link and link one of the libs for every configurations,
is there any problem?
Thank you again!
- Is there any problem if I disable the auto-link for TAUCS lib?, kevin . kai . xu, 06/07/2007
- Re: [cgal-discuss] Is there any problem if I disable the auto-link for TAUCS lib?, Laurent Saboret, 06/07/2007
