  • To:
  • Subject:
  • Date: Sat, 09 Jun 2007 22:15:45 +0800
  • Subject-xx:
Thanks all!
I tried to use "ls /usr/include/qt3 -d" and the output is /usr/include/qt3
My install.log is:
log of ./install_cgal --prefix=/usr/local -with-QT3MT
called by root on Sat Jun 9 22:30:03 CST 2007
CGAL_DIR is /home/mayue/Software/CGAL-3.3
This is install_cgal version 38808.
Looking for POSIX utilities...
getconf is /usr/bin/getconf.
Path for Posix utilities: /bin /usr/bin
basename is /usr/bin/basename.
dirname is /usr/bin/dirname.
uname is /bin/uname.
cat is /bin/cat.
touch is /bin/touch.
cp is /bin/cp.
mv is /bin/mv.
rm is /bin/rm.
ln is /bin/ln.
ls is /bin/ls.
chmod is /bin/chmod.
mkdir is /bin/mkdir.
sed is /bin/sed.
grep is /bin/grep.
tr is /usr/bin/tr.
awk is /usr/bin/awk.
tee is /usr/bin/tee.
find is /usr/bin/find.
tar is /bin/tar.
sed respects newline.
CUSTOM_CXXFLAGS is
Parsing support specfiles for 3rd party libraries:
BOOST
BOOST_PROGRAM_OPTIONS
MS_BOOST_PROGRAM_OPTIONS
BOOST_BIMAP
X11
GMP
GMPXX
MPFR
ZLIB
ZLIBMS
APPLEVECLIB
SUNPERFORMANCECC
SUNPERFORMANCEGCC
SGICOMPLIB
MKL64
MKL32
MKLWIN64
MKLWIN32
ACML
ACMLWIN
BLASIFORTATLAS
BLASGCCATLAS
BLASWINATLAS
REFBLASGCC
REFBLASLINUXGCC
REFBLASSHARED
REFBLASWIN
LEDA
LEDA5X
LEDAMS
LEDA5XMS
LEDAWIN
LEDAWINMS
OPENGL
OPENGL_W32
LAPACK
LAPACKWIN
REFLAPACKLINUXGCC
REFLAPACKWIN
QT3MT
QT3ST
QT3MSMT
QT3MSST
TAUCSWINLAPACK
TAUCSWINATLAS
TAUCSLAPACK
TAUCSATLAS
TAUCSFREEBSDLAPACK
TAUCSFREEBSDATLAS
TAUCSDARWIN
TAUCSIRIXCC32
TAUCSIRIXCC64
CGAL version is 3.3.
Looking for GNU/make...
make is /usr/bin/make.
make found in $PATH is GNU Make.
use _let_expr() for evaluating arithmetic expressions.
OS is i686_Linux-2.6.
Cached COMPILER...
g++@GNU@/usr/bin/gcc@/@
Found compiler GNU 4.1.2.
g++ is /usr/bin/g++.
gcc is /usr/bin/gcc.
Compiler version test compiled.
Cached COMPILER...
i686_Linux-2.6_g++-4.1.2 has already been registered.
Choosing GNU 4.1.2 as compiler.
Cached CGAL_INSTALL_VERSION... 38808
Cached BOOST_INCL_DIR...
Cached BOOST_LIB_DIR...
Cached BOOST_VERSION... 1.33.1
Cached BOOST_PROGRAM_OPTIONS_INCL_DIR...
Cached BOOST_PROGRAM_OPTIONS_LIB_DIR...
Cached BOOST_PROGRAM_OPTIONS_VERSION... 1.33.1
Cached BOOST_BIMAP_INCL_DIR...
Cached BOOST_BIMAP_LIB_DIR...
Cached BOOST_BIMAP_VERSION...
Cached X11_INCL_DIR...
Cached X11_LIB_DIR...
Cached X11_VERSION... 11.0
Cached GMP_INCL_DIR...
Cached GMP_LIB_DIR...
Cached GMP_VERSION...
Cached GMPXX_INCL_DIR...
Cached GMPXX_LIB_DIR...
Cached GMPXX_VERSION...
Cached MPFR_INCL_DIR...
Cached MPFR_LIB_DIR...
Cached MPFR_VERSION...
Cached ZLIB_INCL_DIR...
Cached ZLIB_LIB_DIR...
Cached ZLIB_VERSION... 1.2.3
Cached BLAS_INCL_DIR...
Cached BLAS_LIB_DIR...
Cached BLAS_VERSION... 0
Cached LAPACK_INCL_DIR...
Cached LAPACK_LIB_DIR...
Cached LAPACK_VERSION... 0
Cached ATLAS_INCL_DIR...
Cached ATLAS_LIB_DIR...
Cached ATLAS_VERSION... 0
Cached LEDA_INCL_DIR...
Cached LEDA_LIB_DIR...
Cached LEDA_VERSION...
Cached LEDAWIN_INCL_DIR...
Cached LEDAWIN_LIB_DIR...
Cached LEDAWIN_VERSION...
Cached OPENGL_INCL_DIR...
Cached OPENGL_LIB_DIR...
Cached OPENGL_VERSION... 2.1
Cached QT_INCL_DIR... /usr/include/qt3
Cached QT_LIB_DIR... /usr/share/qt3/lib
Cached QT_VERSION...
Cached TAUCS_INCL_DIR...
Cached TAUCS_LIB_DIR...
Cached TAUCS_VERSION... 2.x
Cached BOOST_SUPPORT... y
Cached BOOST_PROGRAM_OPTIONS_SUPPORT... y
Cached MS_BOOST_PROGRAM_OPTIONS_SUPPORT...
Cached BOOST_BIMAP_SUPPORT...
Cached X11_SUPPORT... y
Cached GMP_SUPPORT...
Cached GMPXX_SUPPORT...
Cached MPFR_SUPPORT...
Cached ZLIB_SUPPORT... y
Cached ZLIBMS_SUPPORT...
Cached APPLEVECLIB_SUPPORT...
Cached SUNPERFORMANCECC_SUPPORT...
Cached SUNPERFORMANCEGCC_SUPPORT...
Cached SGICOMPLIB_SUPPORT...
Cached MKL64_SUPPORT...
Cached MKL32_SUPPORT...
Cached MKLWIN64_SUPPORT...
Cached MKLWIN32_SUPPORT...
Cached ACML_SUPPORT...
Cached ACMLWIN_SUPPORT...
Cached BLASIFORTATLAS_SUPPORT...
Cached BLASGCCATLAS_SUPPORT... y
Cached BLASWINATLAS_SUPPORT...
Cached REFBLASGCC_SUPPORT...
Cached REFBLASLINUXGCC_SUPPORT...
Cached REFBLASSHARED_SUPPORT...
Cached REFBLASWIN_SUPPORT...
Cached LEDA_SUPPORT...
Cached LEDA5X_SUPPORT...
Cached LEDAMS_SUPPORT...
Cached LEDA5XMS_SUPPORT...
Cached LEDAWIN_SUPPORT...
Cached LEDAWINMS_SUPPORT...
Cached OPENGL_SUPPORT... y
Cached OPENGL_W32_SUPPORT...
Cached LAPACK_SUPPORT... y
Cached LAPACKWIN_SUPPORT...
Cached REFLAPACKLINUXGCC_SUPPORT...
Cached REFLAPACKWIN_SUPPORT...
Cached QT3MT_SUPPORT...
Cached QT3ST_SUPPORT...
Cached QT3MSMT_SUPPORT...
Cached QT3MSST_SUPPORT...
Cached TAUCSWINLAPACK_SUPPORT...
Cached TAUCSWINATLAS_SUPPORT...
Cached TAUCSLAPACK_SUPPORT... y
Cached TAUCSATLAS_SUPPORT...
Cached TAUCSFREEBSDLAPACK_SUPPORT...
Cached TAUCSFREEBSDATLAS_SUPPORT...
Cached TAUCSDARWIN_SUPPORT...
Cached TAUCSIRIXCC32_SUPPORT...
Cached TAUCSIRIXCC64_SUPPORT...
Cached CUSTOM_CXXFLAGS...
Cached CUSTOM_LDFLAGS...
Cached LONG_NAME_PROBLEM...
Cached ENABLE_SHARED... y
Cached ENABLE_STATIC... y
BOOST test passed.
BOOST_PROGRAM_OPTIONS test passed.
X11 test passed.
ZLIB test passed.
BLASGCCATLAS test passed.
OPENGL test passed.
LAPACK test passed.
TAUCSLAPACK test passed.
Settings stored in
/home/mayue/Software/CGAL-3.3/config/install/i686_Linux-2.6_g++-4.1.2.
remark: makefile_i686_Linux-2.6_g++-4.1.2 already exists,
saving as .bak.
Compilation of libCGAL static i686_Linux-2.6_g++-4.1.2 succeeded.
vvvvvvvvvvvv build log for libCGAL static shown below vvvvvvvvvvvv
/usr/bin/g++ -O2 -Wall -frounding-math
'-I/home/mayue/Software/CGAL-3.3/include/CGAL/config/i686_Linux-2.6_g++-4.1.2'
'-I/home/mayue/Software/CGAL-3.3/include' -DCGAL_USE_F2C -DCGAL_USE_F2C -c
assertions.cpp
Bbox_2_intersections.cpp
Bbox_3_intersections.cpp
cgal_logo.cpp
Color.cpp
File_header_extended_OFF.cpp
File_header_OFF.cpp
File_scanner_OFF.cpp
File_writer_inventor.cpp
File_writer_OFF.cpp
File_writer_VRML_2.cpp
File_writer_wavefront.cpp
Geomview_stream.cpp
Interval_arithmetic.cpp
io.cpp
JAMA_numeric_solver.cpp
KDS_Log.cpp
kernel.cpp
MP_Float.cpp
numeric_solvers_support.cpp
NefPolynomial.cpp
Random.cpp
Real_timer.cpp
Timer.cpp
Turkowski_numeric_solver.cpp
ar cr ''libCGAL.a \
assertions.o Bbox_2_intersections.o Bbox_3_intersections.o
cgal_logo.o Color.o
File_header_extended_OFF.o File_header_OFF.o File_scanner_OFF.o
File_writer_inventor.o File_writer_OFF.o File_writer_VRML_2.o
File_writer_wavefront.o Geomview_stream.o Interval_arithmetic.o io.o
JAMA_numeric_solver.o KDS_Log.o kernel.o MP_Float.o numeric_solvers_support.o
NefPolynomial.o Random.o Real_timer.o Timer.o Turkowski_numeric_solver.o \
/bin/cat >/dev/null libCGAL.a
/usr/bin/make clean_temp_files
make[1]: Entering directory `/home/mayue/Software/CGAL-3.3/src/CGAL'
rm -f assertions.o Bbox_2_intersections.o Bbox_3_intersections.o cgal_logo.o
Color.o File_header_extended_OFF.o File_header_OFF.o File_scanner_OFF.o
make[1]: Leaving directory `/home/mayue/Software/CGAL-3.3/src/CGAL'
mv libCGAL.a '/home/mayue/Software/CGAL-3.3/lib/i686_Linux-2.6_g++-4.1.2'
^^^^^^^^^^^^ build log for libCGAL static shown above ^^^^^^^^^^^^
Compilation of libCGAL shared i686_Linux-2.6_g++-4.1.2 succeeded.
vvvvvvvvvvvv build log for libCGAL shared shown below vvvvvvvvvvvv
/usr/bin/g++ -fPIC -O2 -Wall -frounding-math
assertions.cpp
cgal_logo.cpp
Color.cpp
File_header_OFF.cpp
File_writer_OFF.cpp
Geomview_stream.cpp
io.cpp
KDS_Log.cpp
kernel.cpp
MP_Float.cpp
NefPolynomial.cpp
Random.cpp
Real_timer.cpp
Timer.cpp
/usr/bin/g++ -shared -o ''libCGAL.so.2.0.0 -Wl,-soname,libCGAL.so.2 \
cgal_logo.o Color.o
'-L/home/mayue/Software/CGAL-3.3/lib/i686_Linux-2.6_g++-4.1.2'
-Wl,-R/usr/local/lib
for symlink in libCGAL.so libCGAL.so.2; do \
rm -f "$symlink"; \
ln -s "libCGAL.so.2.0.0" "$symlink"; \
done
mv libCGAL.so.2.0.0
mv "$symlink"
'/home/mayue/Software/CGAL-3.3/lib/i686_Linux-2.6_g++-4.1.2'; \
done
^^^^^^^^^^^^ build log for libCGAL shared shown above ^^^^^^^^^^^^
Compilation of libCGALimageIO static i686_Linux-2.6_g++-4.1.2 succeeded.
vvvvvvvvvvvv build log for libCGALimageIO static shown below vvvvvvvvvvvv
'-I/home/mayue/Software/CGAL-3.3/include' -DCGAL_USE_F2C -DCGAL_USE_F2C -I.
-c
ImageIO.cpp
-c
analyze.cpp
-c
bmp.cpp
-c
bmpendian.cpp
-c
bmpread.cpp
-c
convert.cpp
-c
gif.cpp
-c
gis.cpp
-c
inr.cpp
-c
iris.cpp
-c
pnm.cpp
-c
recbuffer.cpp
-c
recline.cpp
-c
reech4x4.cpp
ar cr ''libCGALimageIO.a \
ImageIO.o analyze.o bmp.o bmpendian.o bmpread.o convert.o gif.o
gis.o inr.o
iris.o pnm.o recbuffer.o recline.o reech4x4.o \
/bin/cat >/dev/null libCGALimageIO.a
make[1]: Entering directory `/home/mayue/Software/CGAL-3.3/src/CGALimageIO'
rm -f ImageIO.o analyze.o bmp.o bmpendian.o bmpread.o convert.o gif.o gis.o
inr.o
make[1]: Leaving directory `/home/mayue/Software/CGAL-3.3/src/CGALimageIO'
mv libCGALimageIO.a
^^^^^^^^^^^^ build log for libCGALimageIO static shown above ^^^^^^^^^^^^
Compilation of libCGALimageIO shared i686_Linux-2.6_g++-4.1.2 succeeded.
vvvvvvvvvvvv build log for libCGALimageIO shared shown below vvvvvvvvvvvv
-c
ImageIO.cpp
-c
analyze.cpp
-c
bmp.cpp
-c
bmpendian.cpp
-c
bmpread.cpp
-c
convert.cpp
-c
gif.cpp
-c
gis.cpp
-c
inr.cpp
-c
iris.cpp
-c
pnm.cpp
-c
recbuffer.cpp
-c
recline.cpp
-c
reech4x4.cpp
/usr/bin/g++ -shared -o ''libCGALimageIO.so.2.0.0
-Wl,-soname,libCGALimageIO.so.2
gis.o inr.o
-Wl,-R/usr/local/lib -lz
for symlink in libCGALimageIO.so libCGALimageIO.so.2; do \
rm -f "$symlink"; \
ln -s "libCGALimageIO.so.2.0.0" "$symlink"; \
done
inr.o
mv libCGALimageIO.so.2.0.0
mv "$symlink"
done
^^^^^^^^^^^^ build log for libCGALimageIO shared shown above ^^^^^^^^^^^^
Compilation of libCGALPDB static i686_Linux-2.6_g++-4.1.2 succeeded.
vvvvvvvvvvvv build log for libCGALPDB static shown below vvvvvvvvvvvv
PDB_Atom.cpp
PDB_Protein_pdb.cpp
PDB_align.cpp
PDB_Error_logger.cpp
PDB_Quaternion.cpp
PDB_distance.cpp
PDB_Model.cpp
PDB_Residue.cpp
PDB_pdb_utils.cpp
PDB_PDB.cpp
PDB_Residue_data.cpp
PDB_transforms.cpp
PDB_Protein.cpp
PDB_Transform.cpp
ar cr ''libCGALPDB.a \
PDB_Atom.o PDB_Protein_pdb.o PDB_align.o PDB_Error_logger.o
PDB_Quaternion.o
PDB_distance.o PDB_Model.o PDB_Residue.o PDB_pdb_utils.o PDB_PDB.o
PDB_Residue_data.o PDB_transforms.o PDB_Protein.o PDB_Transform.o \
/bin/cat >/dev/null libCGALPDB.a
make[1]: Entering directory `/home/mayue/Software/CGAL-3.3/src/CGALPDB'
rm -f PDB_Atom.o PDB_Protein_pdb.o PDB_align.o PDB_Error_logger.o
PDB_Quaternion.o
make[1]: Leaving directory `/home/mayue/Software/CGAL-3.3/src/CGALPDB'
mv libCGALPDB.a '/home/mayue/Software/CGAL-3.3/lib/i686_Linux-2.6_g++-4.1.2'
^^^^^^^^^^^^ build log for libCGALPDB static shown above ^^^^^^^^^^^^
Compilation of libCGALPDB shared i686_Linux-2.6_g++-4.1.2 succeeded.
vvvvvvvvvvvv build log for libCGALPDB shared shown below vvvvvvvvvvvv
PDB_Atom.cpp
PDB_Protein_pdb.cpp
PDB_align.cpp
PDB_Quaternion.cpp
PDB_distance.cpp
PDB_Model.cpp
PDB_Residue.cpp
PDB_pdb_utils.cpp
PDB_PDB.cpp
PDB_transforms.cpp
PDB_Protein.cpp
PDB_Transform.cpp
/usr/bin/g++ -shared -o ''libCGALPDB.so.2.0.0 -Wl,-soname,libCGALPDB.so.2 \
PDB_Quaternion.o
-Wl,-R/usr/local/lib -lCGAL
for symlink in libCGALPDB.so libCGALPDB.so.2; do \
rm -f "$symlink"; \
ln -s "libCGALPDB.so.2.0.0" "$symlink"; \
done
PDB_Quaternion.o
mv libCGALPDB.so.2.0.0
mv "$symlink"
done
^^^^^^^^^^^^ build log for libCGALPDB shared shown above ^^^^^^^^^^^^
Install
CGAL
headers succeeded.
Install
CGAL
libraries succeeded.
Install
CGAL
programs succeeded.
(/bin/cp /home/mayue/Software/CGAL-3.3/make/makefile_i686_Linux-2.6_g++-4.1.2
/usr/local/share/cgal/cgal.mk)
Install
CGAL
Makefile succeeded.
