Re: [cgal-discuss] Convert Ray_2 (Filtered_kernel) to Line_arc_2 (Circular Kernel)
- To:
- Subject: Re: [cgal-discuss] Convert Ray_2 (Filtered_kernel) to Line_arc_2 (Circular Kernel)
- Date: Wed, 13 Jun 2007 14:48:44 +0200
Thomas Zangl wrote:
wrote:
How to convert a K::Ray_2 to a Circular_k::Line_arc_2?
It cannot work: rays go to infinity, while 'line arcs' have two finite
(possibly algebraic) endpoints.
You are right and the clipping of the ray makes them finite but, I was
also unable to convert a segment to a Line_Arc_2. I worked-a-round using
the << and >> operators and a tempfile (for debugging).
But this is inefficient and ugly :-)
This is my work-a-round code, maybe you can show my the right way to
cast the Segment into Line_Arc_2:
I see a constructor of Line_arc_2 fron Segment_2 documented in the manual:
http://www.cgal.org/Manual/3.3/doc_html/cgal_manual/Circular_kernel_2_ref/Class_Line_arc_2.html#Cross_link_anchor_452
Line_arc_2<CircularKernel> la ( CircularKernel::Segment_2 s);
Monique Teillaud
- Convert Ray_2 (Filtered_kernel) to Line_arc_2 (Circular Kernel), Thomas Zangl - Home, 06/06/2007
- Re:[cgal-discuss] Convert Ray_2 (Filtered_kernel) to Line_arc_2 (Circular Kernel), Thomas Zangl - Home, 06/08/2007
- Re: [cgal-discuss] Convert Ray_2 (Filtered_kernel) to Line_arc_2 (Circular Kernel), Laurent Rineau, 06/08/2007
- Re:[cgal-discuss] Convert Ray_2 (Filtered_kernel) to Line_arc_2 (Circular Kernel), Thomas Zangl - Home, 06/10/2007
- Message not available
- Re: [cgal-discuss] Convert Ray_2 (Filtered_kernel) to Line_arc_2 (Circular Kernel), Thomas Zangl, 06/13/2007
- Re: [cgal-discuss] Convert Ray_2 (Filtered_kernel) to Line_arc_2 (Circular Kernel), Monique . Teillaud, 06/13/2007
- Re:[cgal-discuss] Convert Ray_2 (Filtered_kernel) to Line_arc_2 (Circular Kernel), Thomas Zangl - Home, 06/13/2007
