- To:
- Subject: Re: [cgal-discuss] Converting from Circular to Exact Kernel (once again) ...
- Date: Thu, 14 Jun 2007 16:01:19 +0200
Thomas Zangl wrote:
Dear List,
typedef CGAL::Exact_predicates_exact_constructions_kernel K;
Then the coordinates of K::Point_2 are basically rationals (roughly, filtered Quotient<MP_float>).
How to convert from Circular_Arc_Point to Point
You cannot: a circular arc point has coordinates that are algebraic numbers of degree 2 (CGAL::Root_of_2).
But a K::Point_2 has coordinates lying in a field type.
As you know, algebraic numbers of degree 2 do not form a field.
Otherwise we would not have invented a new name for circular arc point, we would just have re-used Point_2.
and vice versa as loss-less as possible?
you should use the constructor from Point_2 to Circular_arc_point_2
E.g. I get an Circular_Arc_Point as the result of an intersection using
the Circular_Kernel. Now I want to check if the Point is inside or
outside of an Polygon_2 (defined by K):
This functionality is not provided. The basic predicates would involve computations in an extension field of degree > 2.
You may want to try to play with Cartesian<CORE::Expr> but then you will have to do many things 'by hand'.
I guess the manual chapter Arithmetic and Algebra could help on generalities about number types.
Best,
- Converting from Circular to Exact Kernel (once again) ..., Thomas Zangl, 06/14/2007
- Re: [cgal-discuss] Converting from Circular to Exact Kernel (once again) ..., Monique . Teillaud, 06/14/2007
