cgal-discuss - Re: [cgal-discuss] Problem with point collinearity
  • To:
  • Subject: Re: [cgal-discuss] Problem with point collinearity
  • Date: Fri, 15 Jun 2007 14:28:51 +0200
wrote:
Hi,
thank you very very much for your help, it worked perfectly.
However, the double points that I want to check the collinearity are
"alleatory" (i.e., I don“t know them in advance). There is any easy way to
convert them to a rational type number?
There is an operator>> that reads a decimal floating-point literal such
as "1.4" into a rational number of type CGAL::Gmpq; the conversion is
lossless (see the doc of CGAL::Gmpq). As pointed out by Sylvain, if
you have already read "1.4" into a double value, it's too late to
recover the decimal value 1.4 exactly.
Bernd Gaertner.
