- To:
- Subject: Re: [cgal-discuss] Triangle selection
- Date: Tue, 19 Jun 2007 14:33:46 +0200
Thanks it works perfectly!
Is there a method that just removes from the Delaunay transformation
all triangles which are on the line walk without changing the
triangulation?
A dt.remove_line_walk(aa, bb); for instance ?
Best,
Tyv
2007/6/19, Laurent Rineau
On Tuesday 19 June 2007 12:15:24 pm Tyver Ray wrote:
> Line_face_circulator lfi = Line_face_circulator(aa, bb, dt);
Use:
Line_face_circulator lfi = dt.line_walk(aa, bb);
Laurent Rineau
INRIA - Sophia Antipolis
BP 93, 2004 Route des Lucioles
06902 Sophia Antipolis Cedex FRANCE
- Triangle selection, Tyver Ray, 06/19/2007
- Re: [cgal-discuss] Triangle selection, Andreas Fabri, 06/19/2007
- Re: [cgal-discuss] Triangle selection, Tyver Ray, 06/19/2007
- Re: [cgal-discuss] Triangle selection, Laurent Rineau, 06/19/2007
