cgal-discuss - RE: [cgal-discuss] Triangulation: Strange Edges
  • To:
  • Subject: RE: [cgal-discuss] Triangulation: Strange Edges
  • Date: Thu, 21 Jun 2007 01:15:53 -0600
Andreas:
J'ai vu que vous m'avez envoye un e-mail sur a mon adresse perso mais j'ai
tellement de messages en attente sur celle-ci que je n'ai pas eu le temps
encore de le depiler. De quoi s'agissait-il?
Cordialement
Philippe
-----Original Message-----
[mailto:]
Sent: Wed 6/20/2007 11:56 PM
To: Thomas Zangl - Home;
Subject: Re: [cgal-discuss] Triangulation: Strange Edges
Thomas,
Forget my previous posting.
Dual edges may be outside the convex hull. Take the attached
illustration. The dual of the triangle is outside the triangle,
because the Voronoi vertex is the center of the circumsphere of
the triangle. Hence the dual edge of the upper left edge
of the triangle does not intersect the edge.
andreas
ps.: Can you please remove your reply-to field
It makes little sense to raise questions to a
list and expect private answers. Others may
have the same question (maybe later, so they
search the archive), and additionally it shows
that this is not a black hole where questions
disappear unanswered
Thomas Zangl - Home wrote:
> Am Wed, 20 Jun 2007 16:57:13 +0200, schrieb "Andreas Fabri"
>> With weight 1 it should be the same as a Delaunay
>> triangulation.
> I tried it with a Delaunay Triangulation with the same result. I see
> these edges created by the dual voronoi diagram here:
> Triangulation-edge: 55.2482 -0.0703464 51.4652 2.69164e-06 creates:
> 50.4596 -155.826 52.5008 -46.0617
> Triangulation-edge: 49.4532 -1.88372e-06 55.2482 -0.0703464 creates:
> 50.4596 -155.826 48.4359 -322.535
> Strange dual edges?
> Shouldn't the dual edge of a triangulation intersect the triangulation
> edge?
> Best regards,
<<winmail.dat>>
