- To:
- Subject: Re: [cgal-discuss] Problem about Halfedge
- Date: Thu, 21 Jun 2007 12:14:00 +0200
Now i use the midpoint of the dual of the edge's endpoint (this delaunay edge should be finite) to calculate the direction of the ray. But not perfect, has anyone
a suggestion?
2007/6/17, <>:
Hi all,
I am a new user of CGAL.
Now i have a question about the Halfedge.
I created a Voronor diagram in 2D from input points. And i want to draw all the edges. But when i use Edge_iterator to access the edges , i have problem with some edges that have either source or target, but not both. I can get only one point and don't know how to get direction.
Can anybody help me? Thanks
greeting
Kuan
- Problem about Halfedge, tiankuan, 06/17/2007
- Re: [cgal-discuss] Problem about Halfedge, Kuan, 06/21/2007
- Re: [cgal-discuss] Problem about Halfedge, Kuan, 06/24/2007
