- To:
- Subject: Re: [cgal-discuss] Can't load 3D mesh
- Date: Mon, 25 Jun 2007 09:33:25 +0200
- Organization: Inria, Sophia Antipolis, FRANCE
On Monday 25 June 2007 05:12:27 Lyndon Hill wrote:
> Hello,
> I am trying to load a 3D mesh from an OFF file using
> CGAL::scan_OFF(). The mesh has been generated by some
> simplification software.
> I get the following error:
> CGAL::Polyhedron_incremental_builder_3<HDS>::
> lookup_halfedge(): input error: facet 302 shares a
> halfedge from vertex 214 to vertex 213 with facet 300.
> I don't quite understand why two facets sharing a
> halfedge is a bad thing.
Two facets can share an edge. That is not a problem. What is a problem is two
facets sharing an *half-edge*. It means that the two adjacent facets are not
oriented correctly. If the two facets orientations were compatible, the two
facets would have opposite half-edges, to represent the edge that they share.
You need to orient your mesh correctly.
Laurent Rineau
INRIA - Sophia Antipolis
BP 93, 2004 Route des Lucioles
06902 Sophia Antipolis Cedex FRANCE
- Can't load 3D mesh, Lyndon Hill, 06/25/2007
- Re: [cgal-discuss] Can't load 3D mesh, Laurent Rineau, 06/25/2007
- Re: [cgal-discuss] Can't load 3D mesh, Pierre Alliez, 06/25/2007
- Re: [cgal-discuss] Can't load 3D mesh, Marco Attene, 06/26/2007
- Re: [cgal-discuss] Can't load 3D mesh, Lyndon Hill, 06/27/2007
