cgal-discuss - Re: [cgal-discuss] Voronoi Diagram problem
  • To:
  • Subject: Re: [cgal-discuss] Voronoi Diagram problem
  • Date: Mon, 2 Jul 2007 08:51:44 +0200
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=beta; h=received:message-id:date:from:to:subject:in-reply-to:mime-version:content-type:references; b=mTJKxt0m6tEzuWouLY8BjfszCyfimeK+16t9ErMTuwhQwMYNdTGacYD6C6IZjDLZXRH2HWfEyPnOD3xk+C12NBbO+lT+YEtTL+kq9lm2SIFawYclDY8SrgJ3wT/UdvK5YpKfX+2zOCbOXWOrkMsJZHABNwkaP8YSxeFaIzuoMdg=
Hi Camille,
thanks a lot! It helps!
Kuan
2007/7/1, <>:
Le Dim 1 juillet 2007 18:24, Kuan a écrit :
> Hi all,
> I have a problem with Voronoi Diagram.
> I want to transfer a infinite Voronoi Diagram edge(which is a Halfedge) to
> Ray_2;
> I do it like this.
> DT::Edge e = ec->dual();   //ec is the infinite Halfedge
>                 dt.dual(e);        //dt is the dual of the Voronoi Diagram
> vd, but it doesn't work here
It should work. What is happening exactly?
Did you define dt correctly, as in the following?
const DT& dt = vd.dual();
If the const& is missing, dt will not be the underlying triangulation but
a copy of it. This may be the cause of your problems.
Camille
