- To:
- Subject: Re: [cgal-discuss] OFF file reading error
- Date: Wed, 04 Jul 2007 19:00:10 +0200
Hi Kiran,
your file cannot be handled by Polyhedron_3 since it is not a
2-manifold.
Peter
On Wed, 2007-07-04 at 11:54 +0200, Kiran Varanasi wrote:
> Dear All
> I would like to report a problem I am facing with reading certain OFF
> files. I declare
> ifstream is(filename);
> Polyhedron_3 p;
> is >> p;
> and when I print
> p.size_of_facets(), p.size_of_vertices()
> I am getting 0 facets , 0 vertices and so on.
> I am attaching the file in question, please check if you face the same
> problem. I am curious if it is a bug with CGAL or if there is another
> error in my program. I doubt the latter because the same code works
> well with certain other OFF files.
> Regards
> Kiran
- OFF file reading error, Kiran Varanasi, 07/04/2007
- Re: [cgal-discuss] OFF file reading error, Peter Hachenberger, 07/04/2007
