- To:
- Subject: Re: [cgal-discuss] Jet_fitting_3 example and Lapack
- Date: Thu, 05 Jul 2007 14:42:36 +0200
Isabel wrote:
Hi all,
I can't compile Jet_fittin_3 example.
This is the error and the message:
error LNK2019: extern symbol _dgelss_ unsolved, reference in function "void __cdecl CGAL::LAPACK::dgelss(int *,int *,int *,double *,int *,double *,int *,double *,double *,int *,double *,int *,int *)"
why? if Lapack is precompiled. Perhaps the problem is Lapack in Taucs?
Isabel.
Hi Isabel,
I guess you are on windows. Did you install with the installer or
from the tar.gz In the first case did you mark the checkbox
that you want taucs and lapack precompiled libs.
andreas
- Jet_fitting_3 example and Lapack, Isabel, 07/05/2007
- Re: [cgal-discuss] Jet_fitting_3 example and Lapack, Andreas Fabri, 07/05/2007
