- To:
- Subject: Re: [cgal-discuss] 3D Voronoi Diagram
- Date: Thu, 5 Jul 2007 15:50:56 +0200
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=beta; h=received:message-id:date:from:to:subject:in-reply-to:mime-version:content-type:references; b=PJqR3iw+Hcg9Wbiz+SW5Qz3ziL4KsqlArPHy2HbCYQermUBiMNWMuHqmHoSorK1PytW0l2UW/Xh2599/PdOKjwLABpsQiICFLCm0NhgfKZpSMIPSY6kpyfS+KiE/pNoWUOpdMPyrXT/eIn4qsUyOw0dp//9LSZ1DBLOD+83qZwI=
Hi Andreas
Thank you for your answer! I will try that.
best regards
Kuan
2007/7/5, Andreas Fabri <>:
Kuan wrote:
> Hi all,
> Does anyone know how to build a 3D Voronoi Diagram. I cann't find any
> example in the manual.
> thanks a lot.
> greets
> Kuan
Hi Kuan,
There is no equivalent to Voronoi_diagram_2 if that is what
you are looking for.
So you must use the Delaunay_triangulation_3 and use the dual()
functions.
best regards,
andreas
- 3D Voronoi Diagram, Kuan, 07/05/2007
- Re: [cgal-discuss] 3D Voronoi Diagram, Andreas Fabri, 07/05/2007
- Re: [cgal-discuss] 3D Voronoi Diagram, Kuan, 07/05/2007
