- To:
- Subject: Re: [cgal-discuss] Bug in Delaunay insertion?
- Date: Mon, 9 Jul 2007 16:00:07 +0200
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=beta; h=received:message-id:date:from:sender:to:subject:in-reply-to:mime-version:content-type:references:x-google-sender-auth; b=ecNmIz+86QnE3F+dzoESVBZyppEicgh5npm/7blP/mDMGRlOzz9fOlGoIq7VAv9cus3DY6+WYeCrCBf2FoO2Y+0i5YMdq2Iv8xXwhl53pmXoWcfOb3+VHLBDukUPiNqP5S1fQeQ90kyQ9pZZ6n77kpyqz29S+bm0+TAyvzKroFg=
Hello,
Thanks for your answer Laurent. It appeared in a particular case of my program with these points...I'll try to do it another way.
I have another problem it's to insert point in my Delaunay:
I'd like to know how to insert a point to go from Figure 1 to Figure 2 ;
Figure 1 : one triangle on the corner
Figure 2 : two triangles on the same corner
Try 1 : I tried to insert a point on the coordinates of the red symbol to deal with this problem. But I have the error :
CGAL error: precondition violation!
Expr: orientation(p, f->vertex(ccw(li))->point(), f->vertex(cw(li))->point()) == LEFT_TURN
File: c:\program files\cgal-3.3\include\cgal\triangulation
_2.h
Line: 971
Try 2 : I tried to use the insert_in_edge function at the red symbol coordinates. The program works but when I use the line_walk function I have a NULL lfc...
How can I deal with this issue?
Thank you.
Best regards,
Patrick
Line: 971
Thank you.
Best regards,
Patrick
2007/7/9, Laurent Rineau <>:
On Monday 09 July 2007 10:00:50 Patrick Hétroy wrote:
> Hello !
> I'm trying to insert few points with the random function...
> But the code crashes at line_walk code line.
You have inserted points that all have y()==100. It leads to
dt.dimension()==1, which is a special case where the line_walk() function
cannot be used.
Why have you inserted all your points on a line (in the xy-plane)?
Laurent Rineau
INRIA - Sophia Antipolis
BP 93, 2004 Route des Lucioles
06902 Sophia Antipolis Cedex FRANCE
- Bug in Delaunay insertion?, Patrick Hétroy, 07/09/2007
- Re: [cgal-discuss] Bug in Delaunay insertion?, Laurent Rineau, 07/09/2007
- Re: [cgal-discuss] Bug in Delaunay insertion?, Patrick Hétroy, 07/09/2007
