- To:
- Subject: Re: [cgal-discuss] problems with custom point class...
- Date: Mon, 9 Jul 2007 10:14:35 -0400
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=beta; h=received:message-id:date:from:sender:to:subject:in-reply-to:mime-version:content-type:references:x-google-sender-auth; b=Sb9jLz1m5V59ZRPQfJADHeInR7Usxs0khqCevfgsLJtcu9SebVV1IyB8E3dpX6oR+jUkV7Lg47c8kbWZxkU8MmHJeFX5K5NhuLbfiWfMnDVNdujZDQxVNn1LUgiMENL3ScLDDQgyzWH2r49++QPdhmCrEY9mGSKDU8uw+f37yuo=
Camille,
Yes you are exactly right. Thanks for the reply. I noticed the same problem when I was home working on this problem this weekend. Thanks again for the suggestion.
J.D.
On 7/8/07, <> wrote:
Le Jeu 5 juillet 2007 16:47, John Yamokoski a écrit :
> I get a failed assertion during runtime after I insert one of my points
> into a tree.
> Does this have something to do with me
> dynamically allocating storage inside the point class?
Yes indeed: you forgot to define a copy constructor that copies the data
array.
Camille
- problems with custom point class..., John Yamokoski, 07/05/2007
- Re: [cgal-discuss] problems with custom point class..., Camille . Wormser, 07/08/2007
- Message not available
- Re: [cgal-discuss] problems with custom point class..., John Yamokoski, 07/09/2007
