- To:
- Subject: Bug in Delaunay?
- Date: Mon, 9 Jul 2007 13:08:53 +0200
You're right I have the same problem...
---------- Forwarded message ----------
Date: 9 juil. 2007 08:24
To:
Hello !
I'm trying to insert few points with the random function...
But the code crashes at line_walk code line.
Is there a reason?
In advance, thank you!
Yours sincerely,
Patrick
My code :
#include <iostream>
#include <string>
#include <fstream>
#include <list>
using namespace std;
#include <CGAL/Exact_predicates_inexact
_constructions_kernel.h>
#include <CGAL/Triangulation_euclidean_traits_xy_3.h>
#include <CGAL/Delaunay_triangulation_2.h>
#include <CGAL/Triangulation_line_face_circulator_2.h>
struct K : CGAL::Exact_predicates_inexact_constructions_kernel {};
typedef CGAL::Triangulation_euclidean_traits_xy_3<K> Gt;
typedef CGAL::Delaunay_triangulation_2<Gt> Delaunay;
typedef Delaunay::Line_face_circulator Line_face_circulator;
typedef Delaunay::Face_circulator Face_circulator;
typedef Delaunay::Face_handle Face_handle;
typedef Delaunay::Vertex_handle Vertex_handle;
typedef K::Point_3 Point3;
#define START_X 0
#define START_Y 0
#define END_X 100
#define END_Y 100
int main()
Delaunay dt;
srand ( time(NULL) );
for(int i=0; i < 100; i++)
dt.insert(Point3(rand()%100, 100, rand()%20));
list<Point3> listOfBorderPoints;
const Point3& start = Point3(END_X, END_Y, 0);
const Point3& end = Point3(START_X, END_Y, 0);
Line_face_circulator lfc = dt.line_walk(start, end), done(lfc);
if (lfc != (CGAL_NULL_TYPE) NULL)
do
//Scan all the vertices of each triangles on the border
if( !dt.is_infinite(lfc) )
listOfBorderPoints.push_back( lfc->vertex(0)->point() );
while (++lfc != done);
return 0;
#define START_X 0
#define START_Y 0
#define END_X 100
#define END_Y 100
int main()
Delaunay dt;
do
return 0;
- Bug in Delaunay?, Tyver Ray, 07/09/2007
