- To:
- Subject: Re: [cgal-discuss] CGAL and Boost
- Date: Tue, 10 Jul 2007 06:29:11 -0800
Hi prof. Pion,
Thanks for your help.
You are right. I was using gcc 3.4.6.
But I changed to gcc 4.1.2, and I am still getting errors.
Basically, there are three error messages:
1. /usr/include/boost/graph/max_cardinality_matching.hpp:601: error:
'null_vertex' is not a member of
'boost::graph_traits<CGAL::Delaunay_triangulation_2...'
2. /usr/include/boost/graph/max_cardinality_matching.hpp:623: error: no
matching function for call to 'get(...)'
3. /usr/include/boost/graph/max_cardinality_matching.hpp:626: error: no
matching function for call to 'put(...) '
Should I have to add these methods to the Delaunay_triangulation_2 graph
traits?
The error messages and the source code are attached to this email.
Best regards,
Vicente Helano.
> -----Original Message-----
> From:
> Sent: Thu, 05 Jul 2007 09:43:40 +0200
> To:
> a écrit :
>> Dear Friends,
>> I am trying to compute maximum matchings of 2d triangulations using the
>> Boost
>> algorithms library, but I am getting a lot of errors.
> Hi Vicente,
> You did not mention the compiler you are using.
> Note that g++ 3.3 has some problems with the BGL adapters,
> it might be this problem, in which case you could try a more
> recent g++.
> Sylvain Pion
> INRIA Sophia-Antipolis
> Geometrica Project-Team
> CGAL, http://cgal.org/
maximum_matching.log
Description: Binary data
maximum_matching.cpp
- CGAL and Boost, helano, 07/03/2007
- Re: [cgal-discuss] CGAL and Boost, Sylvain Pion, 07/05/2007
- Re: [cgal-discuss] CGAL and Boost, Vicente Helano Batista, 07/10/2007
- Re: [cgal-discuss] CGAL and Boost, Vicente Helano, 07/17/2007
