Re: [cgal-discuss] Point insertion in Triangulation_2 with Triangulation_euclidean_traits_xy_3
- To:
- Subject: Re: [cgal-discuss] Point insertion in Triangulation_2 with Triangulation_euclidean_traits_xy_3
- Date: Fri, 13 Jul 2007 14:01:20 +0200
On Tue, 10 Jul 2007 18:08:17 +0200, Mariette Yvinec <> wrote:
I got the same error on my computer.
This failure comes from a numerical problem since it disappears if you replace,
in both the include and typedef line :
Exact_predicates_inexact_constructions_kernel
by
Exact_predicates_exact_constructions_kernel
Obviously this Delaunay triangulation should not require
a kernel with exact constructions. The problem
is that, as it is coded now, the predicates are not exact
when the kernel are instantiated with Exact_predicates_inexact_constructions_kernel.
Thanks for reporting the bug.
Dear Mariette,
thank you for your prompt reply. Using Exact_predicates_exact_constructions_kernel solved the problem in the testcase as well as in my application.
Best regards,
Eivind LM
- Point insertion in Triangulation_2 with Triangulation_euclidean_traits_xy_3, Eivind LM, 07/09/2007
- Re: [cgal-discuss] Point insertion in Triangulation_2 with Triangulation_euclidean_traits_xy_3, Mariette Yvinec, 07/10/2007
- Re: [cgal-discuss] Point insertion in Triangulation_2 with Triangulation_euclidean_traits_xy_3, Eivind LM, 07/13/2007
- Re: [cgal-discuss] Point insertion in Triangulation_2 with Triangulation_euclidean_traits_xy_3, Mariette Yvinec, 07/13/2007
