cgal-discuss - Re: [cgal-discuss] link error of taucs
  • To:
  • Subject: Re: [cgal-discuss] link error of taucs
  • Date: Fri, 13 Jul 2007 19:39:38 +0200
  • Organization: INRIA Sophia-Antipolis
Hi Panjia,
This is a bug in CGAL's Taucs_fix.h :
I was able to reproduce the bug by including this header in 2 .cpp files.
Functions defined in this file are copies of TAUCS functions with bug fixes. In a header file, they should be marked "inline".
Just drop the attached file in CGAL-3.3\include\CGAL.
Sorry for the inconvenience,
Laurent Saboret
panjia a écrit :
Hello,
I use cgal taucs lib in my static link library B. When I use this library in
other project A, I have this link error:
error LNK2005: _cgal_taucs_available_memory_size already define in A.obj.
How can I solve this problem?
panjia
2007-07-13
// Copyright (c) 2005 INRIA (France).
// All rights reserved.
// This file is part of CGAL (www.cgal.org); you may redistribute it under
// the terms of the Q Public License version 1.0.
// See the file LICENSE.QPL distributed with CGAL.
// Licensees holding a valid commercial license may use this file in
// accordance with the commercial license agreement provided with the
software.
// This file is provided AS IS with NO WARRANTY OF ANY KIND, INCLUDING THE
// WARRANTY OF DESIGN, MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
// $URL:
svn+ssh://scm.gforge.inria.fr/svn/cgal/branches/CGAL-3.3-branch/Surface_mesh_parameterization/include/CGAL/Taucs_fix.h
// $Id: Taucs_fix.h 38842 2007-05-24 14:52:02Z lsaboret $
// Author(s) : Laurent Saboret, Pierre Alliez, Bruno Levy
#ifndef CGAL_TAUCS_FIX
#define CGAL_TAUCS_FIX
// Include TAUCS main header taucs.h
#ifndef CGAL_INCLUDED_TAUCS_H
#define CGAL_INCLUDED_TAUCS_H
// GCC 3.x does not compile if we include complex.h within "extern C {}"
// and complains that this header is deprecated.
#if defined(__GNUC__)
#undef __DEPRECATED
#include <complex.h>
#endif
// taucs.h will define min/max macros if it's not already done (e.g. by
Windows.h).
#ifndef min
#define CGAL_TAUCS_DEFINES_MIN
#endif
#ifndef max
#define CGAL_TAUCS_DEFINES_MAX
#endif
// TAUCS is a C library
extern "C" {
#include <taucs.h>
// Undefine Taucs' min/max macros to avoid an error
// with std::min()/std::max() calls in standard C++ headers.
#ifdef CGAL_TAUCS_DEFINES_MIN
#undef min
#endif
#ifdef CGAL_TAUCS_DEFINES_MAX
#undef max
#endif
#endif
#ifdef OSTYPE_linux
#include <unistd.h>
#include <math.h>
#endif
extern "C"
/* FIX OF taucs_system_memory_size() */
/* returns size of memory reported by the operating system */
/* should not normally be called by the user (call _avail_) */
/* (see taucs_memory.c) */
#ifdef OSTYPE_linux
/* Redirect call to avoid link error */
#define taucs_system_memory_size cgal_taucs_system_memory_size
inline double taucs_system_memory_size()
/* LS 2006: The original code below is buggy on Linux 2.6 */
/* (because /proc/meminfo format changed) */
#if 0
FILE* f;
double m;
double m_sc;
m_sc = (double) sysconf(_SC_PAGESIZE);
m_sc *= (double) sysconf(_SC_PHYS_PAGES);
/* total memory is the first number in /proc/meminfo */
f = fopen("/proc/meminfo","r");
if (f==NULL) return m_sc;
if (fscanf(f,"%*[a-zA-Z :\n\r]%lf",&m) != 1) return m_sc;
if (m != m_sc) {
taucs_printf("Warning: /proc/meminfo reports %lfMB of memory while\n",
m/1048576.0);
taucs_printf(" sysconf reports %lfMB of memory\n",
m_sc/1048576.0);
return m;
#endif
/* LS 2006: fix */
double m_sc;
return m_sc;
#endif
/* LS 2007: Cygwin implementation */
#ifdef OSTYPE_cygwin
double m_sc;
m_sc = (double) 4096; /* page size */
return m_sc;
#endif
/* FIX OF taucs_available_memory_size() */
/* returns size of memory available for allocation */
/* Redirect calls to avoid link error */
#define taucs_available_memory_size cgal_taucs_available_memory_size
#define taucs_malloc malloc
#define taucs_free(ptr) if (ptr != NULL) free(ptr)
/* LS 2007: if m_sys is meaningful, then we limit malloc test by 0.75*m_sys */
#define limit_memory(mem) ((mem) < m_max ? (mem) : m_max)
inline double taucs_available_memory_size()
/* LS 2007: The original code below creates an infinite loop on Linux */
/* (optimistic memory allocation => malloc() never returns NULL) */
#ifndef OSTYPE_linux
double m_sys;
double m,m_low,m_high,m_tol;
char* p;
double m_max;
m_sys = taucs_system_memory_size();
if (m_sys > 0)
m_max = floor(0.75 * m_sys);
else
m_max = DBL_MAX;
/* malloc test */
m = 1048576.0;
while ( (m < m_max-1) /* m_max not reached */
&& ((p=(char*) taucs_malloc( (size_t) limit_memory(m*2.0) )) != NULL)
taucs_printf("taucs_avail_memory_size: %.0lf Mb\n", limit_memory(m*2.0) /
1048576.0);
taucs_free(p);
m = limit_memory(m*2.0);
m_low = m;
m_high = limit_memory(m*2.0);
m_tol = m / 128.0;
while ( m_high - m_low > m_tol ) {
m = m_low + ( (m_high-m_low)/2.0 );
taucs_printf("taucs_avail_memory_size: [%.0lf %.0lf %.0lf]\n",
m_low / 1048576.0,
m / 1048576.0,
m_high / 1048576.0);
if ( (p=(char*) taucs_malloc( (size_t) m )) != NULL )
m_low = m;
else
m_high = m;
taucs_free(p);
m = m_low;
taucs_printf("taucs_avail_memory_size: malloc test=%.0lf MB sys test=%.0lf
MB\n",
m / 1048576.0,
m_sys / 1048576.0
return m;
#else /* LS 2007: workaround Linux optimistic memory allocation */
double m_sys; /* size of physical memory */
double m; /* size of memory available for allocation */
m_sys = (double) sysconf(_SC_PAGESIZE);
m_sys *= (double) sysconf(_SC_PHYS_PAGES);
/* we limit m by 0.75*m_sys */
m = floor(0.75 * m_sys);
taucs_printf((char*)"taucs_available_memory_size returns %lfMB\n",
m/1048576.0);
return m;
#endif
} // extern "C"
#endif // CGAL_TAUCS_FIX
  • link error of taucs, panjia, 07/13/2007
    • Re: [cgal-discuss] link error of taucs, Laurent Saboret, 07/13/2007
