cgal-discuss - Extensible Kernel
Extensible Kernel
  • To:
  • Subject: Extensible Kernel
  • Date: Mon, 16 Jul 2007 09:25:36 +0200
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=beta; h=received:message-id:date:from:to:subject:mime-version:content-type; b=peSNRgdre2NoQQnvc1VPq6mV7UCKBV3jza3W4+sgyQFh2Y79qX9+kU5F2y00immHzZ+2EAcKmF6KHKSewWDfizaZgi5f2Zs1MbaTQNoVuMrp2027YlNVtRJtr4R4w2x7yAuk8taTSJamFmBZJThmBJFr3DhjSNSuFNxjpi2K4Ss=
Hi all,
I have some problem about Extensible Kernel. I define a Point_3 by myself. But it works ok for Deaunay_Triangulation, but it doesn't work with Neighbor_serach and Plane_3.  like below:
typedef CGAL::Search_traits_3<K> TreeTraits;
typedef CGAL::Orthogonal_k_neighbor_search<TreeTraits> Neighbor_search;
typedef Neighbor_search::Tree Tree;
and for Plane_3, it doesn't work as i define K::Plane_3(p1,p2,p3). Am i defining my Point_3 in a wrong way? I just want to add some information in it.
I define my Point_3 like this:
#ifndef MY_POINTC3_H
#define MY_POINTC3_H
#include <CGAL/Origin.h>
#include <CGAL/Bbox_3.h>
class MyPointC3 {
private:
    double vec[3];
    double ar;    //area
    bool inc; //include in crust
    double val;
public:
    MyPointC3()
        : ar(1),val(0)
        *vec = 0;
        *(vec+1) = 0;
        *(vec+2) = 0;
    MyPointC3(const double x, const double y, const double z, double c = 1,double v = 0, bool i = true)
        : ar(c),val(v),inc(i)
        *vec = x;
        *(vec+1) = y;
        *(vec+2) = z;
    const double& x() const  { return *vec; }
    double & x() { return *vec; }
    void setX(double x){*vec = x;}
    const double& y() const { return *(vec+1); }
    double& y() { return *(vec+1); }
    void setY(double y){*(vec+1) = y;}
    const double& z() const { return *(vec+2); }
    double& z() { return *(vec+2); }
    void setZ(double z){*(vec+2) = z;}
    double area() const { return ar; }
    double& area() { return ar; }
    double value() const { return val; }
    double& value() { return val; }
    const bool& included() const { return inc; }
    bool & included(){return inc;}
    bool operator==(const MyPointC3 &p) const
        return ( *vec == *(p.vec) )  && ( *(vec+1) == *(p.vec + 1)) && ( *(vec+2) == *(p.vec + 2));
    bool operator!=(const MyPointC3 &p) const
        return !(*this == p);
template <class ConstructBbox_3>
class MyConstruct_bbox_3 : public ConstructBbox_3 {
public:
    CGAL::Bbox_3 operator()(const MyPointC3& p) const {
        return CGAL::Bbox_3(p.x(), p.y(), p.z(), p.x(), p.y(), p.z());
class MyConstruct_coord_iterator {
public:
    const double* operator()(const MyPointC3& p)
        return &p.x();
    const double* operator()(const MyPointC3& p, int)
        const double* pyptr = &p.z();
        pyptr++;
        return pyptr;
template <typename K, typename OldK>
class MyConstruct_point_3
    typedef typename K::RT         RT;
    typedef typename K::Point_3    Point_3;
    typedef typename K::Line_3     Line_3;
    typedef typename Point_3::Rep  Rep;
public:
    typedef Point_3                result_type;
    typedef CGAL::Arity_tag< 1 >   Arity;
    // Note : the CGAL::Return_base_tag is really internal CGAL stuff.
    // Unfortunately it is needed for optimizing away copy-constructions,
    // due to current lack of delegating constructors in the C++ standard.
    Rep // Point_2
        operator()(CGAL::Return_base_tag, CGAL::Origin o) const
    { return Rep(o); }
    Rep // Point_2
        operator()(CGAL::Return_base_tag, const RT& x, const RT& y, const RT& z) const
    { return Rep(x, y, z); }
    Rep // Point_2
        operator()(CGAL::Return_base_tag, const RT& x, const RT& y, const RT& z, const RT& w) const
    { return Rep(x, y, z, w); }
    Point_3
        operator()(CGAL::Origin o) const
    { return MyPointC3(0, 0, 0,0); }
    Point_3
        operator()(const RT& x, const RT& y, const RT& z) const
        return MyPointC3(x, y, z ,0);
    Point_3
        operator()(const Line_3& l) const
        typename OldK::Construct_point_3 base_operator;
        Point_3 p = base_operator(l);
        return p;
    Point_3
        operator()(const Line_3& l, int i) const
        return base_operator(l, i);
    // We need this one, as such a functor is in the Filtered_kernel
    Point_3
        operator()(const RT& x, const RT& y,const RT& z, const RT& w) const
        if(w != 1){
            return MyPointC3(x/w, y/w,z/w, 0);
        } else {
            return MyPointC3(x,y,z, 0);
std::ostream &
operator<<(std::ostream &os, const MyPointC3 &p)
    switch(os.iword(CGAL::IO::mode)) {
case CGAL::IO::ASCII :
    return os << p.x() << ' ' << p.y() <<' '<<p.z();
case CGAL::IO::BINARY :
    CGAL::write(os, p.x());
    CGAL::write(os, p.y());
    CGAL::write(os, p.z());
    return os;
default:
    return os << "MyPointC3(" << p.x() << ", " << p.y()<<", "<< p.z() ;
std::istream &
operator>>(std::istream &is, MyPointC3 &p)
    double x, y, z;
    int c;
    switch(is.iword(CGAL::IO::mode)) {
    is >> x >> y>>z;
    break;
    CGAL::read(is, x);
    CGAL::read(is, y);
    CGAL::read(is, z);
    break;
default:
    std::cerr << "" << std::endl;
    std::cerr << "Stream must be in ascii or binary mode" << std::endl;
    break;
    if (is) {
        p = MyPointC3(x, y,z);
    return is;
#endif // MY_POINTC3_H
and use it in my kernel
#ifndef MYKERNEL_H
#define MYKERNEL_H
#include <CGAL/Cartesian.h>
#include "MyPointC3.h"
// K_ is the new kernel, and K_Base is the old kernel
template < typename K_, typename K_Base >
class MyCartesian_base
    : public K_Base::template Base<K_>::Type
    typedef typename K_Base::template Base<K_>::Type   OldK;
public:
    typedef K_                                Kernel;
    typedef MyPointC3                         Point_3;
    typedef MyConstruct_point_3<Kernel, OldK>       Construct_point_3;
    typedef const double*                     Cartesian_const_iterator_3;
    typedef MyConstruct_coord_iterator        Construct_cartesian_const_iterator_3;
    typedef MyConstruct_bbox_3<typename OldK::Construct_bbox_3>
        Construct_bbox_3;
    Construct_point_3
        construct_point_3_object() const
    { return Construct_point_3(); }
    template < typename Kernel3 >
    struct Base { typedef MyCartesian_base<Kernel3, K_Base>  Type; };
template < typename FT_ >
struct MyKernel
    : public CGAL::Type_equality_wrapper<
    MyCartesian_base<MyKernel<FT_>, CGAL::Cartesian<FT_> >,
    MyKernel<FT_> >
#endif // MYKERNEL_H
best regards
Kuan
