- To:
- Subject: Re: [cgal-discuss] CGAL-3.3 and Intel compiler (9 or 10) on Linux
- Date: Fri, 20 Jul 2007 15:46:27 -0700
Hi all,
It appears that the ifdef definitions for Intel compiler in Point_2.h, Point_3.h, Vector_2.h and Vector_3.h using Self when Intel compiler is used don't work. Using Point_2, Point_3, Vector_3 instead of Self do work.
So for those interested in using icc on linux, this needs to be changed and the option -Kc++ should be added in the compiler and linker options in the installer (still not clear why...).
Thanks Sylvain for the ifdef tip.
Julie
Julie Bernauer wrote:
Hi all,
I was just wondering whether anybody has CGAL-3.3 compiling with Intel Compilers 9 or 10 on Linux.
The CGAL installer does not seem to add the options automatically for compiling and I guess I missed something which gives me this error:
vvvvvvvvvvvv error log for libCGAL static shown below vvvvvvvvvvvv
icc -O2 -mp '-I/home/julie/Sources/CGAL/CGAL-3.3/CGAL-3.3/include/CGAL/config/i686_Linux-2.6_icc-9.1' '-I/home/julie/Sources/CGAL/CGAL-3.3/CGAL-3.3/include' -Kc++ -c assertions.cpp
icc -O2 -mp '-I/home/julie/Sources/CGAL/CGAL-3.3/CGAL-3.3/include/CGAL/config/i686_Linux-2.6_icc-9.1' '-I/home/julie/Sources/CGAL/CGAL-3.3/CGAL-3.3/include' -Kc++ -c Bbox_2_intersections.cpp
/home/julie/Sources/CGAL/CGAL-3.3/CGAL-3.3/include/CGAL/Point_2.h(80): error: expected an identifier
(const T1 &x, const T2 &y)
The only custom flag I have is -Kc++ for compiler and linker as in this configuration, icc does not seem to detect it is c++ files (this detection works outside of CGAL, that's why I think I missed something...).
Below are my librairies version for information.
Thanks very much in advance for your help,
Julie
Julie Bernauer
Levitt group, Computational Structural Biology, Clark Center S255
318 Campus Drive, Stanford CA94305, USA
Tel: +1 (650) 723 5720 Fax: +1 (650) 724 4021
- CGAL-3.3 and Intel compiler (9 or 10) on Linux, Julie Bernauer, 07/21/2007
- Re: [cgal-discuss] CGAL-3.3 and Intel compiler (9 or 10) on Linux, Julie Bernauer, 07/21/2007
