- To:
- Subject: search strucures
- Date: Thu, 2 Aug 2007 17:37:22 +0200
- Organization: IIASA - Institut for Applied Systems Analysis
Bonjour la liste,
I'm thinking about using a cgal seach structure (either 2D nearest
neigbor/range, or dD spatial searching) for my simulation. I have looked at
the manual and tried some examples, but am still not sure if cgal is
appropriate for my needs. I would appreciate some input from someone who has
some actual experience with nearest neighbor searching.
So, what I need to do is the following:
- I'll have to store about 100-10000 points (cartesian coordinates, normal
doubles or floats, standard euclidean metric). I need 2D points now, but
could at some point in the future make use of 3-5 dimensions. That's not
absolutely necessary, though.
- I need to store information along with the coordinates, or at least an
integer index.
- I need to remove and reinsert nodes frequently. Typically, I'd remove and
insert a handful of random nodes and then pick one random point and do a
neighbor search on it.
- When performing a search, I'll need to find about k = 1-100 neighbors.
Approximate search would be fine, I could specify either k directly or a
(circular) range. I'd use incremental search only rarely and could avoid it
altogether at the expense of giving a maybe overly generous range or number k.
I don't see (yet?) how to associate an index with the Point_2<> thingy, and
the k-d tree doesn't seem to support node removal. Is that correct or did I
overlook something? How is the relative performance of these to structures
in the 2D case? Is there a point in using it at all, when I need to update
my nodes frequently as described?
Thank you,
Rupert
Rupert Mazzucco
Research Scholar, Evolution and Ecology Program
IIASA - Institute for Applied Systems Analysis
Schlossplatz 1, 2361 Laxenburg, Austria
Phone: +43 2236 807 522 Fax: +43 2236 713 13
- search strucures, Rupert Mazzucco, 08/02/2007
