- To:
- Subject: Re: [cgal-discuss] Nef_3 and Polyedrhon
- Date: Sun, 5 Aug 2007 12:47:53 +0200
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=beta; h=received:message-id:date:from:to:subject:in-reply-to:mime-version:content-type:content-transfer-encoding:content-disposition:references; b=cLdLqRlSVanIZpixNu0iC0kDhUnfZIKc7xnExqScBQqF1J/od7r+s5/JPYp75ASOUIn5J9ojSawbYtC+VFPzk1Nm2Y1Soo7wg2BFSPrwCO2dVU99ftidFPtjZjgZwISb+wdek27ZJQBNK7qVA3BrVNH9xBi1dcGDYTDcg1EYfjc=
I find the solution, you need read the polyedron in one variable P for
example, and finally, when you need write the content of the
Nef_polyedhra, use the convert to polyedron with other polyedra
variable Q, for example, and then it run correctly, here the new code:
int main() {
Polyhedron P, Q;
char *path;
path = "polyhedron.off";
Q = readOFF (path);
if(Q.is_closed()) {
Nef_polyhedron N1(Q);
if(N1.is_simple()) {
N1.convert_to_Polyhedron(P);
std::cout << P;
std::cout << "Número de Vértices: ";
std::cout << P.size_of_vertices ();
else
std::cerr << "N1 is not a 2-manifold." << std::endl;
Thanks for the help, this is the solution.
Bye
On 8/4/07, Rubén Martínez
wrote:
> The complete code is this:
> #include <CGAL/Gmpz.h>
> #include <CGAL/Homogeneous.h>
> #include <CGAL/Polyhedron_3.h>
> #include <CGAL/IO/Polyhedron_iostream.h>
> #include <CGAL/Nef_polyhedron_3.h>
> #include <CGAL/IO/Nef_polyhedron_iostream_3.h>
> #include <iostream>
> #include <fstream>
> typedef CGAL::Homogeneous<CGAL::Gmpz> Kernel;
> typedef CGAL::Polyhedron_3<Kernel> Polyhedron;
> typedef CGAL::Nef_polyhedron_3<Kernel> Nef_polyhedron;
> typedef Kernel::Vector_3 Vector_3;
> typedef Kernel::Aff_transformation_3 Aff_transformation_3;
> using namespace std;
> Polyhedron readOFF(char *p)
> Polyhedron P;
> ifstream file;
> file.open(p);
> file >> P;
> return P;
> int main() {
> Polyhedron P;
> char *path;
> P = readOFF (path);
> if(P.is_closed()) {
> Nef_polyhedron N1(P);
> std::cout << P;
> else
> Is a copy of a one example of basic CGAL, with some changes, but I dot
> know because I have this problem...
> On 8/3/07, Peter Hachenberger
> wrote:
> > Hi Ruben,
> > I've never seen that happen before. CAn you please send me the whole
> > code, i.e., with type definitions. As far as I can see, this part of the
> > code is fine.
> > Peter
> > On Fri, 2007-08-03 at 12:49 +0200, Rubén Martínez wrote:
> > > My problem reside in de transformation from Nef 3 to Polyedron, this
> code:
> > > My complete code is this:
> > > main(){
> > > Polyhedron P;
> > > char *path;
> > > P = readOFF (path);
> > > if(P.is_closed()) {
> > > std::cout << P;
> > > else
> > > And when I convert N1 (Nef 3) to P (Polyedron) i observe that the
> > > vertex are duplicated, for example:
> > > In this tetrahedron, i f I load this in the Nef 3, i have this:
> > > OFF
> > > 8 6 0
> > > # vertices
> > > -1 -1 1
> > > -1 1 1
> > > 1 1 1
> > > 1 -1 1
> > > -1 -1 -1
> > > -1 1 -1
> > > 1 1 -1
> > > 1 -1 -1
> > > # facets
> > > 4 3 2 1 0
> > > 4 0 1 5 4
> > > 4 6 5 1 2
> > > 4 3 7 6 2
> > > 4 4 7 3 0
> > > 4 4 5 6 7
> > > but if I execute the code N1.convert_to_Polyhedron(P); i obtain this
> > result
> > > OFF
> > > 16 12 0
> > > -1 -1 1
> > > -1 1 1
> > > 1 1 1
> > > 1 -1 1
> > > -1 -1 -1
> > > -1 1 -1
> > > 1 1 -1
> > > 1 -1 -1
> > > -1 -1 1
> > > -1 1 1
> > > 1 1 1
> > > 1 -1 1
> > > -1 -1 -1
> > > -1 1 -1
> > > 1 1 -1
> > > 1 -1 -1
> > > 4 3 2 1 0
> > > 4 0 1 5 4
> > > 4 6 5 1 2
> > > 4 3 7 6 2
> > > 4 4 7 3 0
> > > 4 4 5 6 7
> > > 4 12 15 11 8
> > > 4 12 8 9 13
> > > 4 8 11 10 9
> > > 4 12 13 14 15
> > > 4 15 14 10 11
> > > 4 13 9 10 14
> > > Anyone know any solution for this problem?????
> > > Thanks
> > > RMG
> > You are currently subscribed to cgal-discuss.
> > To unsubscribe or access the archives, go to
> > https://lists-sop.inria.fr/wws/info/cgal-discuss
- [cgal-discuss] Nef_3 and Polyedrhon, Rubén Martínez, 08/03/2007
- Re: [cgal-discuss] Nef_3 and Polyedrhon, Peter Hachenberger, 08/03/2007
- Re: [cgal-discuss] Nef_3 and Polyedrhon, Rubén Martínez, 08/04/2007
- Re: [cgal-discuss] Nef_3 and Polyedrhon, Rubén Martínez, 08/05/2007
- Re: [cgal-discuss] Nef_3 and Polyedrhon, Peter Hachenberger, 08/06/2007
