- To:
- Cc: "Tyver Ray" <>
- Subject: Re: [cgal-discuss] Get near vertices
- Date: Mon, 6 Aug 2007 14:25:17 +0200
- Organization: Inria, Sophia Antipolis, FRANCE
On Monday 06 August 2007 12:05:33 Tyver Ray wrote:
> Hello!
> Thank you for the answer. My problem is that I do not know how I can use it
> with my definitions :
> struct K : CGAL::Exact_predicates_inexact_constructions_kernel {};
> typedef CGAL::Triangulation_euclidean_traits_xy_3<K> Gt;
> typedef CGAL::Triangulation_vertex_base_2<Gt> Vb;
> typedef CGAL::Triangulation_face_base_2<Gt> Fb;
> typedef CGAL::Triangulation_data_structure_2<Vb,Fb> Tds;
> typedef CGAL::Point_set_2<Gt, Tds> PS;
> typedef CGAL::Delaunay_triangulation_2<Gt, Tds> Delaunay;
> typedef K::Point_2 Point2;
> typedef K::Point_3 Point3;
> typedef K::Circle_2 Circle;
> First, in the documentation it is said that I have to define a Gt::Circle_2
> but with my triangulation I'm obliged to get it through the Kernel because
> of my Triangulation_euclidean_traits_xy_3<K> Gt.
Well, that traits class Triangulation_euclidean_traits_xy_3<K> was designed
for 2D Delaunay triangulations, and has not been adapted to
Point_set_2<Gt,Tds>. You need to amend that class, so that it is a model of
the concept PointSetTraits:
http://www.cgal.org/Manual/3.3/doc_html/cgal_manual/Point_set_2_ref/Concept_PointSetTraits.html
A few types and predicates need to be added:
Bounded_side_2
Circle_2
Compare_distance_2
Compute_squared_distance_2
Construct_center_2
Construct_circle_2
FT
It should not be too difficult, as long as you use the distance in the plane
xy. Circle_2 is K::Circle_3. Compute_squared_distance_2, Construct_center_2,
and Construct_circle_2 are strait-forward (construct the circle in the
xy-plane). Bounded_side_2 and Compare_distance_2 need to be adapted: see the
other predicates of the traits class.
If you need to use the euclidean 3D distance, then I think that Point_set_2
is
not the solution.
Laurent Rineau
INRIA - Sophia Antipolis
BP 93, 2004 Route des Lucioles
06902 Sophia Antipolis Cedex FRANCE
Tel: +33 4 92 38 78 62
- Re: [cgal-discuss] Get near vertices, Tyver Ray, 08/06/2007
- Re: [cgal-discuss] Get near vertices, Laurent Rineau, 08/06/2007
