- To:
- Subject: Re: [cgal-discuss] Using CGAL::sqrt and CGAL::Gmpq?
- Date: Tue, 7 Aug 2007 10:39:05 +0200
- Organization: Inria, Sophia Antipolis, FRANCE
On Tuesday 07 August 2007 10:22:18 Thomas Zangl - Home wrote:
> Hi!
> I tried to remove the dependency on math.h's sqrt function (and the
> need to convert the variable to_double). So I tried this:
> typedef CGAL::Exact_predicates_exact_constructions_kernel K;
> typedef K::FT dbl;
Use CGAL::Exact_predicates_exact_constructions_kernel_with_sqrt
The reason is that the exact number types, with square roots, are more time
expensive.
Laurent Rineau
INRIA - Sophia Antipolis
BP 93, 2004 Route des Lucioles
06902 Sophia Antipolis Cedex FRANCE
Tel: +33 4 92 38 78 62
- Using CGAL::sqrt and CGAL::Gmpq?, Thomas Zangl - Home, 08/07/2007
- Re: [cgal-discuss] Using CGAL::sqrt and CGAL::Gmpq?, Laurent Rineau, 08/07/2007
- Re:[cgal-discuss] Using CGAL::sqrt and CGAL::Gmpq?, Thomas Zangl - Home, 08/07/2007
