- To:
- Subject: Problem in example mesh_a_3d_gray_image.cpp
- Date: Tue, 21 Aug 2007 14:57:47 +0200
Hi every one,
I used the example examples/Surface_mesher/mesh_a_3d_gray_image.cpp
with no problem as a command line.
I have done an interface using MS-VC++ and it seems that it is not
possible to use the main function two times. I converted this function
into a function taking as input every parameters (an 3D image, a
sphere origin coordinate, a sphere radius, the 3 parameters of the
mesh quality, and the threshold). When I use my interface the first
time, it works but if I call again this function, it doesn't work
anymore. The variable "image" doesn't seem to be well instantiate.
Any suggestion?
Thank you,
Pierre
- Problem in example mesh_a_3d_gray_image.cpp, pierro . villard, 08/21/2007
- Re: [cgal-discuss] Problem in example mesh_a_3d_gray_image.cpp, Laurent Rineau, 08/21/2007
