cgal-discuss - Re: [cgal-discuss] Problem in example mesh_a_3d_gray_image.cpp
  • To:
  • Subject: Re: [cgal-discuss] Problem in example mesh_a_3d_gray_image.cpp
  • Date: Tue, 21 Aug 2007 16:29:08 +0200
  • Organization: Inria, Sophia Antipolis, FRANCE
On Tuesday 21 August 2007 16:14:26
wrote:
> Thank you very much for the help. I am glad to see that this problem is
> already known.
That *may* be a problem related to another one that I already know. You have
not yet given enough information (full version of CGAL, example of code that
is broken...) so that I can have a real clue.
> I don't understand well how I could apply this "pach", how
> could I compile it? Can I just modify the Gray_level_image_3.h file?
You only need to modify the file Gray_level_image_3.h. I have attached the
whole header file coming from CGAL-3.3, and already "patched". Please backup
your current include/CGAL/Gray_level_image_3.h file, put the attached one at
the same place, and recompile your application. You do not need to recompile
CGAL libraries.
Then tell me if the fix address your problem. :-)
Laurent Rineau
INRIA - Sophia Antipolis
BP 93, 2004 Route des Lucioles
06902 Sophia Antipolis Cedex FRANCE
Tel: +33 4 92 38 78 62
// Copyright (c) 2005-2007  INRIA Sophia-Antipolis (France).
// All rights reserved.
// This file is part of CGAL (www.cgal.org); you may redistribute it under
// the terms of the Q Public License version 1.0.
// See the file LICENSE.QPL distributed with CGAL.
// Licensees holding a valid commercial license may use this file in
// accordance with the commercial license agreement provided with the software.
// This file is provided AS IS with NO WARRANTY OF ANY KIND, INCLUDING THE
// WARRANTY OF DESIGN, MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
// $URL: svn+ssh://scm.gforge.inria.fr/svn/cgal/branches/CGAL-3.3-branch/Surface_mesher/include/CGAL/Gray_level_image_3.h $
// $Id: Gray_level_image_3.h 37876 2007-04-03 13:59:17Z lrineau $
// Author(s)     : Laurent RINEAU
#ifndef CGAL_MESH_3_GRAY_LEVEL_IMAGE_3_H
#define CGAL_MESH_3_GRAY_LEVEL_IMAGE_3_H
#include <CGAL/basic.h>
#include <boost/shared_ptr.hpp>
#ifdef CGAL_SURFACE_MESHER_DEBUG_GRAY_LEVEL_IMAGE_3_CONSTRUCTOR
#include <boost/format.hpp>
#endif
/* Copy-paste from <imageio/ImageIO.h> */
struct point_image;
typedef struct point_image _image;
extern void printSupportedFileFormat();
extern _image* _readImage(const char *name);
extern void _freeImage(_image *im);
extern void _get_image_bounding_box(_image*,
			     float*, float*, float*,
			     float*, float*, float*);
extern void convertImageTypeToFloat(_image* image);
extern float triLinInterp(_image* image,float posx, float posy, float posz);
/* End of copy-paste from <imageio/ImageIO.h> */
namespace CGAL {
  template <typename FT, typename Point>
class Gray_level_image_3
  struct Image_deleter {
    void operator()(_image* image)
      std::cerr << ::boost::format("Deletion of image %1%.\n") % image;
      ::_freeImage(image);
#endif
  typedef boost::shared_ptr<_image> Image_shared_ptr;
  Image_shared_ptr image_ptr;
  float isovalue;
  float min_x, min_y, min_z;
  float max_x, max_y, max_z;
  bool is_valid;
public:
  Gray_level_image_3(const char* file, float isoval)
    : isovalue(isoval),
      min_x(0.f),
      min_y(0.f),
      min_z(0.f),
      max_x(0.f),
      max_y(0.f),
      max_z(0.f),
      is_valid(false)
    std::cerr <<
      ::boost::format("Constructing a Gray_level_image_3(\"%1%\")... ") % file;
#endif
    image_ptr = Image_shared_ptr(::_readImage(file), Image_deleter());
    if( image_ptr.get() != 0 )
      std::cerr << ::boost::format(" = %1%\n") % image_ptr.get();
#endif
      is_valid = true;
      ::convertImageTypeToFloat(image_ptr.get());
      isovalue=isoval;
      ::_get_image_bounding_box(image_ptr.get(),
				&min_x, &min_y, &min_z,
				&max_x, &max_y, &max_z);
  ~Gray_level_image_3()
      std::cerr << ::boost::format("~Gray_level_image_3() image=%1%\n") % image;
#endif
  static void print_supported_file_format()
    ::printSupportedFileFormat();
  bool inside(const float X, const float Y, const float Z) const
    return ( X>=min_x && Y>=min_y && Z>=min_z &&
             X<=max_x && Y<=max_y && Z<=max_z );
  FT operator()(Point p) const
    const float X=static_cast<float>(to_double(p.x()));
    const float Y=static_cast<float>(to_double(p.y()));
    const float Z=static_cast<float>(to_double(p.z()));
    if (!inside(X,Y,Z))
      return FT(1);
    else{
      float value = ::triLinInterp(image_ptr.get(), X, Y, Z);
      if (value > isovalue) // inside
	return FT(-1);
      else if (value < isovalue) // outside
	return FT(1);
      else
	return FT(0);
}; // end Gray_level_image_3
} // end namespace CGAL
#endif // CGAL_MESH_3_GRAY_LEVEL_IMAGE_3_H
