- To:
- Subject: Re: [cgal-discuss] Re: performance of 3D-Booleans
- Date: Tue, 28 Aug 2007 18:17:12 +0200
Hi Carlos,
can you access the following link? There you find my test results on
Nef_polyhedron_3.
http://www.sciencedirect.com/science?_ob=ArticleURL&_udi=B6TYS-4NDMN9J-3&_user=499892&_coverDate=09%2F30%2F2007&_rdoc=1&_fmt=&_orig=search&_sort=d&view=c&_acct=C000024518&_version=1&_urlVersion=0&_userid=499892&md5=69e84e1b3e10fe59800d9b78826f1bf4
Peter
On Fri, 2007-08-17 at 21:58 +0200,
wrote:
> Hi,
> Let me share some of my performance numbers; I hope this opens up the
> discussion.
> I have a small prototype that calculates triangle-triangle intersections.
> If my initial points have 8 significant digits, I can calculate
> 170K intersctions per second using extended arithmetic operations. The
> results of the intersections will be stored as exteded precision rational
> numbers. (That is, the results of the numerator and denominator require
> more than 64 bits each.)
> Does anyone have any performance numbers to share?
> Thanks,
> Carlos
- performance of 3D-Booleans, Carlos Carbonera, 08/15/2007
- <Possible follow-up(s)>
- performance of 3D-Booleans, carbonera, 08/15/2007
- Re: performance of 3D-Booleans, carbonera, 08/17/2007
- Re: [cgal-discuss] Re: performance of 3D-Booleans, Peter Hachenberger, 08/28/2007
- Re: [cgal-discuss] Re: performance of 3D-Booleans, Carlos Carbonera, 08/28/2007
