cgal-discuss - Bug in Nef_polyhedron_3 (II v_first, II v_last) ?
  • To:
  • Subject: Bug in Nef_polyhedron_3 (II v_first, II v_last) ?
  • Date: Wed, 29 Aug 2007 08:12:06 +0200
  • Disposition-notification-to: Zorglub78 <>
Hi all,
When I try to use this very trivial code:
#include <CGAL/basic.h>
#include <CGAL/Gmpq.h>
#include <CGAL/Homogeneous.h>
#include <CGAL/Nef_polyhedron_3.h>
typedef CGAL::Gmpz NT;
typedef CGAL::Homogeneous<NT> Kernel3D;
typedef Kernel3D::Point_3 Point3D;
typedef CGAL::Iso_cuboid_3<Kernel3D> Cuboid3D;
typedef CGAL::Nef_polyhedron_3<Kernel3D> Polyhedron3D;
using std::vector;
int main(int argc, char** argv)
Cuboid3D c1(Point3D(0,0,0), Point3D(3,3,3));
vector<Point3D> vp;
for(u_int i=0; i<8; ++i)
vp.push_back(c1[i]);
Polyhedron3D p(vp.begin(), vp.end(), true);
Execution fails with the following error:
"Conversion from vertex cycle to Nef_polyhedron_3 was not successful. Error history: Direction of projection is 'z'. -> Different vertices are projected to same location! Now, direction of projection is 'x'. -> Different vertices are projected to same location! Now, direction of projection is 'y'. -> Different vertices are projected to same location! Finally, empty Nef_polyhedron_3 was constructed."
Am I doing wrong something, or is there a bug in Nef_polyhedron_3 (II v_first, II v_last) ?
Thanks for responses.
