- To:
- Subject: Re: [cgal-discuss] known issue with Nef_polyhedron_3.is_convex() ?
- Date: Wed, 29 Aug 2007 13:42:29 +0200
Hi,
yeah right, that function never really worked. I should have taken it
out.
Peter
On Wed, 2007-08-29 at 08:23 +0200, Zorglub78 wrote:
> Hi Peter.
> I'm back from hollydays ;o)
> In CGAL/Nef_polyhedron_3.h, the method "bool is_convex() const" is in
> the public area of the class, following the method "bool is_convex() const".
> Sure, I've made a mistake, and the method is not documented in the
> manual, but it is a public method in CGAL code.
> I think this method needs to be protected or private...
> Thanks.
> Zorg a écrit :
> > OK, I made a stupid mistake
> > Thanks
> > -----Message d'origine-----
> > De : Peter Hachenberger
> > [mailto:]
> > Envoyé : vendredi 20 juillet 2007 14:16
> > À :
> > Objet : Re: [cgal-discuss] known issue with Nef_polyhedron_3.is_convex() ?
> > There is no funtion Nef_polyhedron_3::is_convex.
> > Where did you find that? No idea why the compiler just does not
> > tell you that the function does not exist.
> > Peter
- Re: [cgal-discuss] known issue with Nef_polyhedron_3.is_convex() ?, Zorglub78, 08/29/2007
- Re: [cgal-discuss] known issue with Nef_polyhedron_3.is_convex() ?, Peter Hachenberger, 08/29/2007
