cgal-discuss - Re: [cgal-discuss] Determining if several points are within a polygon
  • To:
  • Subject: Re: [cgal-discuss] Determining if several points are within a polygon
  • Date: Wed, 29 Aug 2007 16:14:00 +0200
wrote:
I am running an application in which a polygon with holes gets divided into two parts, and I have to determine which holes go to which side. This can be done by checking if a point on the hole is within one of the halfs or another.
However, doing so with CGAL::bounded_side for each point will probably take
me O(n^2) for all holes (provided that there can be n holes). Is there a way
to do one check for all the points at once, using CGAL? (which will take O(n))
Amir.
A kind of plane sweep would do it. Or use the triangulation as follows:
Put the two polygons in a constrained Delaunay triangulation, mark the
faces as being part of A or B or nothing.
Take one point per hole. Sort all those with spatial_sort, and
locate them in the triangulation, taking the resulting face as
hint for where to start the next point location.
andreas
