- To:
- Subject: Re: [cgal-discuss] K-3D and Nef 3D booleans - (almost) success
- Date: Sun, 2 Sep 2007 22:33:27 +0200
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=beta; h=received:from:to:subject:date:user-agent:references:in-reply-to:mime-version:content-type:message-id:sender; b=kdE8FNymcesMR2wP5MkUCni5yjDYZrTXcVbadgapSpNBltf0IMvMAHTlkuS2mrWCkziLYTzX4pDF+TYF+6VOjrvKgEOSrsxR0o23C64E1ZBHWQL48+Oh+/flB0kApWZE10Yt8e7/qBryBDA5bA4WB7bqps8uULyTEB+bv/vCaKk=
On Friday 31 August 2007 17:12:57 Peter Hachenberger wrote:
> If this assertion is thrown, the representation of the polyhedron will
> not be consistent. So catching the assertion means to proceed with an
> incomplete or faulty representation. Why did you revert back from
> SNC_indexed_items? They are faster and give you a better chance of
> succeeding.
At first, they didn't work at all for me. Then I saw the conversion code
needs
to initialise the indices, which I copied over to the k3d-to-nef converter.
Now it works for simple tests (cubes, spheres with 32x16 faces), but more
complicated tests fail with the following assertion violation:
normalized(cet->circle()) == normalized(ce->circle().opposite())
at /usr/local/include/CGAL/Nef_3/SNC_external_structure.h:1153.
I have attached the number type I'm using (kernel:
CGAL::Cartesian<threshold_number>)
regards,
Bart
#ifndef THRESHOLD_NUMBER_H_ #define THRESHOLD_NUMBER_H_ // K-3D // Copyright (c) 1995-2007, Timothy M. Shead // // Contact: // // This program is free software; you can redistribute it and/or // modify it under the terms of the GNU General Public // License as published by the Free Software Foundation; either // version 2 of the License, or (at your option) any later version. // // This program is distributed in the hope that it will be useful, // but WITHOUT ANY WARRANTY; without even the implied warranty of // MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU // General Public License for more details. // // You should have received a copy of the GNU General Public // License along with this program; if not, write to the Free Software // Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA // // As a special exception, you have permission to link this program // with the CGAL (http://www.cgal.org) library and distribute executables, as long as you // follow the requirements of the GNU GPL in regard to all of the // software in the executable aside from CGAL. /** \file \brief Number type that provides comparison operators that have a tolerance specified by a threshold \author Bart Janssens () */ #include <CGAL/number_type_basic.h> #include <utility> #include <cmath> #include <math.h> // for nextafter #include <limits> CGAL_BEGIN_NAMESPACE class threshold_number { public: threshold_number() : d(0.0), t(1e-7) {} threshold_number(double D) : d(D), t(1e-7) {} threshold_number& operator=(const double D) {this->d = D; return *this;} threshold_number& operator*=(const double D) {d *= D; return *this;} threshold_number& operator/=(const double D) {d/= D; return *this;} threshold_number& operator+=(const double D) {d+= D; return *this;} threshold_number& operator-=(const double D) {d-= D; return *this;} threshold_number& operator+=(const threshold_number& T) {d += T.d; return *this;} threshold_number& operator-=(const threshold_number& T) {d -= T.d; return *this;} threshold_number& operator*=(const threshold_number& T) {d *= T.d; return *this;} threshold_number& operator/=(const threshold_number& T) {d /= T.d; return *this;} double d; double t; }; inline threshold_number operator-(const threshold_number& T) { return threshold_number(-T.d); } inline threshold_number operator-(const threshold_number& T1, const threshold_number& T2) { return threshold_number(T1.d-T2.d); } inline threshold_number operator+(const threshold_number& T1, const threshold_number& T2) { return threshold_number(T1.d+T2.d); } inline threshold_number operator*(const threshold_number& T1, const threshold_number& T2) { return threshold_number(T1.d*T2.d); } inline threshold_number operator/(const threshold_number& T1, const threshold_number& T2) { return threshold_number(T1.d/T2.d); } inline bool operator==(const threshold_number& T1, const threshold_number& T2) { return std::abs(T1.d - T2.d) <= T1.t; } inline bool operator!=(const threshold_number& T1, const threshold_number& T2) { return std::abs(T1.d - T2.d) > T1.t; } inline bool operator<(const threshold_number& T1, const threshold_number& T2) { return (T1.d - T2.d) < -T1.t; } inline bool operator>(const threshold_number& T1, const threshold_number& T2) { return (T1.d - T2.d) > T1.t; } inline bool operator<=(const threshold_number& T1, const threshold_number& T2) { return T1 < T2 || T1 == T2; } inline bool operator>=(const threshold_number& T1, const threshold_number& T2) { return T1 > T2 || T1 == T2; } inline std::ostream& operator<<(std::ostream& Stream, const threshold_number& T) { Stream << T.d; return Stream; } ////////////////////////////////// // CGAL required functions ////////////////////////////////// template<> class Is_valid< threshold_number > : public Unary_function< threshold_number, bool > { public : bool operator()( const threshold_number& x ) const { return (x == x); } }; template <> class Algebraic_structure_traits< threshold_number > : public Algebraic_structure_traits_base< threshold_number, Euclidean_ring_tag > { public: typedef Tag_false Is_exact; typedef Tag_true Is_numerical_sensitive; class Sqrt : public Unary_function< Type, Type > { public: Type operator()( const Type& x ) const { return CGAL_CLIB_STD::sqrt( x.d ); } }; class Kth_root : public Binary_function<int, Type, Type> { public: Type operator()( int k, const Type& x) const { CGAL_precondition_msg( k > 0, "'k' must be positive for k-th roots"); return CGAL_CLIB_STD::pow(x.d, 1.0 / static_cast<double>(k)); } }; class Gcd : public Binary_function< Type, Type, Type > { public: Type operator()( const Type& x, const Type& y ) const { if (x == 0 && y == 0) return Type(0.0); return threshold_number(1.0); } Type operator()( const Type& x, const int& y ) const { if (x == 0 && y == 0) return Type(0.0); return threshold_number(1.0); } Type operator()( const int& x, const Type& y ) const { if (x == 0 && y == 0) return Type(0.0); return threshold_number(1.0); } }; class Div_mod { public: typedef Type first_argument_type; typedef Type second_argument_type; typedef Type& third_argument_type; typedef Type& fourth_argument_type; typedef Arity_tag< 4 > Arity; typedef void result_type; void operator()( const Type& x, const Type& y, Type& q, Type& r) const { q.d = x.d/y.d; r.d = 0.0; return; } template < class NT1, class NT2 > void operator()( const NT1& x, const NT2& y, Type& q, Type& r ) const { typedef Coercion_traits< NT1, NT2 > CT; typedef typename CT::Type Type; BOOST_STATIC_ASSERT(( ::boost::is_same<Type , Type >::value)); typename Coercion_traits< NT1, NT2 >::Cast cast; operator()( cast(x), cast(y), q, r ); } }; }; template <> class Real_embeddable_traits< threshold_number > : public Real_embeddable_traits_base< threshold_number > { public: class Is_finite : public Unary_function< Type, bool > { public : bool operator()( const Type& x ) const { return (x.d != std::numeric_limits<Type>::infinity()) && (-x.d != std::numeric_limits<Type>::infinity()) && is_valid(x.d); } }; class To_double : public Unary_function< Type, double > { public: //! the function call. double operator()( const Type& x ) const { return x.d; } }; class To_interval : public Unary_function< Type, std::pair< double, double > > { public: //! the function call. std::pair<double, double> operator()( const Type& x ) const { return std::pair<double,double>( x.d, x.d ); } }; }; inline bool is_integer(threshold_number T) { return CGAL::is_finite(T.d) && (std::ceil(T.d) == T.d); } template <> class Fraction_traits< threshold_number > { public: typedef threshold_number Type; typedef ::CGAL::Tag_false Is_fraction; typedef threshold_number Numerator_type; typedef threshold_number Denominator_type; typedef Algebraic_structure_traits< threshold_number >::Gcd Common_factor; class Decompose { public: typedef threshold_number first_argument_type; typedef threshold_number& second_argument_type; typedef threshold_number& third_argument_type; void operator () (const threshold_number& rat, threshold_number& num,threshold_number& den) { num.d = rat.d; den.d = 1.0; while (std::ceil(num.d) != num.d) { num.d *= 2.0; den.d *= 2.0; } CGAL_postcondition(rat.d == num.d/den.d); } }; }; CGAL_END_NAMESPACE #endif /*THRESHOLD_NUMBER_H_*/
- Re: [cgal-discuss] K-3D and Nef 3D booleans - (almost) success, Bart Janssens, 09/02/2007
- Re: [cgal-discuss] K-3D and Nef 3D booleans - (almost) success, Peter Hachenberger, 09/03/2007
- Re: [cgal-discuss] K-3D and Nef 3D booleans - (almost) success, Bart Janssens, 09/03/2007
- Re: [cgal-discuss] K-3D and Nef 3D booleans - (almost) success, Bart Janssens, 09/08/2007
