- To: CGAL <>
- Subject: Boost graph library and Polyhedron_3
- Date: Mon, 03 Sep 2007 10:20:55 -0700
- Organization: Caltech Multi-Res Modeling Group
Folks,
I am using Polyhedron_3 for algorithms on simplicial surface meshes (arbitrary topology with/without boundary). I need to generate a system of loops and want to use the tree/co-tree algorithm as described by Erickson and Whittlesey. It occurred to me that I should use the Boost graph library for this since Boost is already part of CGAL anyway (in other words: no additional library to install...).
As usual when looking at a whole new library things are a bit overwhelming in terms of getting started. If someone has an example of using Polyhedron_3 as an underlying "graph" to run graph algorithms on using the Boost graph algorithm library that would be most helpful for me in terms of accelerating my getting started with this.
What do I actually need? I need to run Dijkstra from what will be the base point of the system of loops. Then run a maximum spanning tree algorithm on the dual of the *remaining* edges (those not in the Dijkstra tree). Finally I need to find the remaining 2g edges which are neither in the Dijkstra tree nor in the maximum spanning tree and create the loops by connecting the corresponding branches of the Dijkstra tree with the endpoints of each one of these 2g edges. (and then cut and live happily ever after... :))
Any example along the lines of some subset of the above will likely allow me a jump start on getting rolling with this.
Thanks much!
peter
- Boost graph library and Polyhedron_3, Peter Schröder, 09/03/2007
- Re: [cgal-discuss] Boost graph library and Polyhedron_3, Fernando Cacciola, 09/03/2007
- Re: [cgal-discuss] Boost graph library and Polyhedron_3, Peter Schröder, 09/04/2007
- Re: [cgal-discuss] Boost graph library and Polyhedron_3, Fernando Cacciola, 09/04/2007
