- To:
- Subject: Re: [cgal-discuss] Convex hull and Polyhedron_3
- Date: Wed, 05 Sep 2007 10:54:59 +0200
- Organization: LPNHE - Université Paris 6 Pierre et Marie Curie
Bernd Gaertner a écrit :
> both the convex hull algorithms as well as the polyhedron class have
> predefined traits classes that in turn depend on a kernel. One way I see
> is to extend your kernel by replacing Point_3 with your enriched version
> (see section 2.5 on extensible kernels in the manual; this section
> features example code). Then you use this enriched kernel in both
> predefined traits classes. As I never tried this myself, I can't promise
> that it works, though.
Thanks! I will try this.
Cheers,
Laurent
- Convex hull and Polyhedron_3, Laurent Le Guillou, 09/04/2007
- Re: [cgal-discuss] Convex hull and Polyhedron_3, Bernd Gaertner, 09/05/2007
- Re: [cgal-discuss] Convex hull and Polyhedron_3, Laurent Le Guillou, 09/05/2007
