- To:
- Subject: Re: [cgal-discuss] Bug in 3 Planes intersection?
- Date: Mon, 10 Sep 2007 15:16:35 +0200
Dear Amir,
it's a known misconception in using CGAL. The kernel Cartesian<double> is inexact and can't in general guarantee correct results. Please see the FAQ item at http://www.cgal.org/FAQ.html#inexact_NT for more about this topic, and for ways of computing exactly with CGAL.
Best,
Bernd.
wrote:
I use this code:
Result=CGAL::intersection(TwinPlane, NewPlane, AftPlane);
Point3D Target;
bool isdo=assign(Target,Result);
Number d1=CGAL::squared_distance(NewPlane,Target);
Number d2=CGAL::squared_distance(AftPlane,Target);
Number d3=CGAL::squared_distance(TwinPlane,Target);
"Number" beign a cartesian<double> kernel number type, and (TwinPlane, NewPlane,
AftPlane) are all Plane_3<cartesian<double>> types. However, the distances d1,d2,d3 which are
supposed to be 0 (because the point Target is the intersection) are sometimes way off, and the Target
point is not correct. Moreover, when I change the order of the planes in the CGAL::intersection function,
the results sometimes differ. Is that a known bug?
Amir.
- Bug in 3 Planes intersection?, avaxman, 09/10/2007
- Re: [cgal-discuss] Bug in 3 Planes intersection?, 李宝顺, 09/10/2007
- Re: [cgal-discuss] Bug in 3 Planes intersection?, Monique . Teillaud, 09/10/2007
- Re: [cgal-discuss] Bug in 3 Planes intersection?, Bernd Gaertner, 09/10/2007
